ᐅ Is it possible to modify the doors of Ikea Brimnes furniture?
Created on: 8 Nov 2020 19:42
abbari
abbari
8 Nov 2020 19:42
Hello everyone, I am considering modifying the doors of my Ikea Brimnes wardrobe to better fit my room. Specifically, I want to know if it is possible to alter or completely rebuild the doors so that they open differently (e.g., sliding doors instead of hinged doors) or use different hardware and materials without compromising stability or functionality. Has anyone had experience with such modifications? What tools and materials would be necessary, and what important factors should be considered? Thanks in advance for any helpful advice!
gaubla
8 Nov 2020 20:14
abbari schrieb:
whether it is possible to modify or completely rebuild the doors so that they open differently (e.g., sliding doors instead of hinged doors) or can be fitted with different hardware and materials
Basically, it is technically possible to modify Ikea Brimnes doors, but it should be noted that the wardrobe frame and construction are designed for hinged doors. Switching to sliding doors usually requires additional rails and adjustments to the carcass, which are not supported by Ikea.
In terms of tools, a drill, cordless screwdriver, possibly a chisel, and screwdrivers are needed. Materials such as suitable running and closing hardware, and if necessary sliding rails, must be sourced separately. Stability and precise fitting should be the highest priorities during modification.
besau
8 Nov 2020 20:29
I only fitted new handles to my Brimnes doors. For larger modifications, I would recommend reinforcing the carcass first; otherwise, the doors often don't fit properly. Sliding doors are tricky because the frame doesn’t have a guide.
dunitan
8 Nov 2020 21:02
abbari schrieb:
whether it is possible to modify or completely rebuild the doors so that they open differently (e.g., sliding doors instead of hinged doors) or can be fitted with different fittings and materials
Hello! To answer your question in more detail: In principle, there is nothing to prevent modifying the doors of the Ikea Brimnes if you have good carpentry skills. However, the cabinet is designed for hinged doors, so changes like converting to sliding doors may involve additional effort. Here are some points to consider:
- The hinge mounting points are precisely positioned; if you make changes, you will either need to drill new holes (which may affect stability) or use adapters.
- Sliding doors require tracks, whose installation might be difficult due to the Brimnes’ construction, as the side panels are thin and not prepared for track systems.
- Materials can be easily replaced, for example by swapping the doors with custom-made elements—this requires precise measurement.
- Alternatively, you can change the design with paint or vinyl wrap if a full modification seems too complex.
I recommend making a clear plan before starting the modification and possibly a sketch to check exact dimensions and mounting options.
pakokla
8 Nov 2020 21:45
For simple modifications, you can unscrew the doors and install new handles. A full conversion to sliding doors is usually complicated and cannot be done without considerable effort.
Gilbert
9 Nov 2020 07:53
gaubla schrieb:
Switching to sliding doors usually requires additional tracks and modifications to the cabinet, which Ikea does not support.
This is exactly the main point. You have to ask yourself whether you really want to modify the product at all or if another piece of furniture would be a better fit. The myth that Ikea furniture is easy to modify doesn’t really apply here.
Also, sliding doors on a cabinet originally designed for hinged doors often lead to stability issues. However, you usually only notice this after assembly—when all the holes are drilled and the tracks installed. So, you end up paying with time and materials. Is it worth it? I doubt it.
