ᐅ Is it possible to make Ikea Besta weather-resistant for outdoor use?
Created on: 26 Aug 2017 08:37
Teangela
Hello everyone, I am considering using Ikea Besta cabinets outdoors. I am particularly interested in whether it is possible to treat or modify these furniture units to make them weather-resistant. I don’t just mean splash resistance, but also protection against moisture, UV radiation, and temperature fluctuations. Has anyone already had experience with suitable sealants, special coatings, or construction techniques to make Besta suitable for outdoor use despite its relatively inexpensive materials? I would really appreciate practical tips or advice on the limitations of this idea.
Sinan-meo27 Aug 2017 08:44To make a Besta cabinet weatherproof, you need to address the root of the problem: the particleboard and edges. I would recommend sealing all joint surfaces and edges with high-quality epoxy resin or polyurethane (PU) adhesive, as these materials are water-repellent and help prevent the boards from swelling.
After that, you could apply at least two generous coats of exterior paint that is UV- and weather-resistant. However, there is still a residual risk since the durability of particleboard in outdoor conditions cannot be guaranteed in the long term. For heavy moisture exposure, solid wood or special exterior-grade panels are more suitable.
Sinan-meo schrieb:
I would recommend sealing all joint surfaces and edges with high-quality epoxy resin or polyurethane adhesive, as these materials are water-resistantThat sounds very thorough, but it’s also important to consider the effort and costs involved. Maybe it makes sense to experiment in a protected area first, rather than treating everything right away. I think it’s great when someone shares new builds or methods – that’s how we all grow personally.
Silako schrieb:
Which varnishes exactly are being referred to, and how long is the protective effect supposed to last theoretically?Thanks for the hint, Silako. I am considering varnishes such as marine varnish, moisture-resistant polyurethane varnishes, or acrylic varnishes. The durability of the protection is of course an important factor: ideally, something that protects for several months up to a year before needing touch-ups. In practice, however, reapplication every six months is often expected. I am also interested to know if there have been any attempts to impregnate the furniture beforehand with oil or resins, as I consider the particleboard to be the biggest challenge – that is where moisture tends to penetrate the most.
At its core, it is challenging to make Ikea Besta fully weatherproof. However, if you still want to try, you should follow these steps:
- Seal the edges with silicone or epoxy resin
- Treat the surface with several layers of UV-resistant clear varnish
- Ideally, remove the furniture bottom and back panels or replace them with water-repellent material
This, however, is more of an experiment than a permanent solution.
