ᐅ Is it possible to lay patio slabs on gravel over an old foundation?
Created on: 5 Mar 2018 10:45
darek2k5Hello, as the title says, I want to lay new patio slabs on gravel.
The old slabs are 5cm (2 inches) thick and were glued to the foundation. The new slabs are 2cm (0.8 inches) thick.
I want to lay them on gravel because I also want to widen the patio. For that, I would of course need to work with crushed stone and gravel.
Is this safely possible, or what would be the best way to proceed?
HilfeHilfe5 Mar 2018 10:53Of course it works, just compact properly
Baumfachmann5 Mar 2018 12:40If there is a slope, use a drainage mat as the base layer, followed by 3-5cm (1¼-2 inches) of gravel. Otherwise, create a slope using screed. Important: do not omit the drainage mat. When connecting to the widening, compact carefully.
Baumfachmann5 Mar 2018 16:05Only for the foundation. The planned widening with frost protection gravel about 40-50cm (16-20 inches) thick. Moisten the gravel slightly before compacting, vibrate it, and then vibrate it again the next day. This will prevent any settling even after 10 years or more.
