ᐅ Is it possible to have a wall cabinet with a drawer using the IKEA METOD system?
Created on: 4 Oct 2024 00:06
is it possible to install a 20cm (8 inches) drawer from Maximera at the top inside an 80cm (31.5 inches) wall cabinet (side cabinet) from Metod, and then have a 60cm (24 inches) door underneath?
The Metod kitchen planner does not allow this option. However, I am happy to assemble it myself on site.
It is intended to be a sideboard.
kbt09 schrieb:
then basically a base cabinet with reduced depthThat’s why I said “basically” and just wanted to give you the hint that you can basically take the setup from the base cabinets and simply replace the carcass. Although I wouldn’t use the surface of the wall cabinets without a cover panel either. Unless you plan to build further upwards with the wall cabinets. There is also the 80 x 27 x 200 cm (31.5 x 10.6 x 78.7 inches) carcass for that.S
Schorsch_baut4 Oct 2024 08:48ypg schrieb:
What surface do you have? Is it the Veddinge?Yes. I had to check briefly. It is the Veddinge. My wife wanted fronts from another supplier (for now, cough cough, 5 years), but she can't decide on any color. At that time, we chose the cheapest front, which, as far as I'm concerned, can stay as it is.kbt09 schrieb:
just simply replace it.Well, drilling holes also matters with Ikea. What looks doable often turns out to be tricky. At first, I wanted the Knoxhult without a drawer unit, but there are no pre-drilled holes at all, only a shelf is possible.
kbt09 schrieb:
without a cover plateThey are supposed to be arranged in a row of four. Who knows when I’ll manage to get a 240cm (94 inch) countertop that isn’t too expensive. So I’m using plan B with the wall cabinets, because the TV will be placed on top.Schorsch_baut schrieb:
My wife has wanted fronts from another supplier for about... ahem... 5 years now, but she just can't decide on a color.We have the Stensund fronts from IKEA in light green and are very happy with them... They are relatively new – maybe they could be an option for you too.
kbt09 schrieb:
Because the pilot holes for the feet are only in the base cabinetsYes, I know. We weighed it yesterday: rubber feet will be added underneath.Similar topics
