ᐅ Is it possible to equip Ikea PLATSA units with casters (wheels) for easier mobility?
Created on: 5 May 2023 08:47
lumida
lumida
5 May 2023 08:47
Hello everyone, I have a question that has been on my mind for a while: Is it possible to equip the Ikea Platsa furniture series with casters?
I plan to get a PLATSA shelving unit that I want to be able to move around the room occasionally. Since the modules can get quite heavy, it would be ideal to put them on casters. However, I haven’t found any suitable casters for PLATSA in Ikea’s range, nor any official information on this.
Does anyone have experience with retrofitting PLATSA units with casters, whether special adapters are needed, or if this is structurally problematic? Which types of casters are suitable to ensure stability and safety? I would appreciate any explanations, ideas, or even practical tips from personal experience.
Nakar33
5 May 2023 11:22
Hello lumida,
regarding your question about the possibility of equipping Ikea PLATSA with castors, I can provide a more detailed answer, as I implemented a similar solution myself some time ago.
The PLATSA modules are not designed for castors by default, as their construction focuses on stability and modularity without mobility. The furniture is supported by a base plate, which is flat and quite sturdy. Attaching castors therefore first requires a stable substructure that can bear the weight and allow easier movement.
Basically, you have two options:
- You can mount castors directly under the base plates. Lockable furniture castors with a high load capacity are suitable, preferably with a medium to large diameter (about 50-60mm (2-2.4 inches)) to better overcome floor obstacles. However, you would need to screw a support plate or wooden board of a matching size under the PLATSA modules, as the thin base surface alone does not provide enough stability.
- Alternatively, some users use special castor bases, a kind of frame into which the module feet are screwed and which then stand on castors. Here, it is important to carefully check whether the load capacity and the fit of the modules are stable enough.
Important: Since PLATSA is often used primarily as stationary furniture, when converting it with castors you must make sure that the lateral stability is not compromised. Otherwise, the furniture might easily tip over when moved.
My recommendation:
- Avoid very small or cheap castors, which might cause problems on carpet or uneven floors.
- Make sure the castors are lockable to prevent unintended rolling.
- Before finalizing the modification, check that the furniture stands firmly and securely on the substructure.
If you like, I can also send you photos of my self-made solution and provide the exact dimensions of the castor-specific substructure.
lumida
5 May 2023 13:54
Nakar33 schrieb:
You install casters directly under the floor panels. Lockable furniture casters with a high load capacity are suitable for this, preferably with a medium to large diameter (about 50-60mm (2-2.4 inches)) to more easily overcome obstacles on the floor.
Thank you very much for your detailed feedback! Your description sounds very helpful. However, I am wondering exactly how you attached the casters under the floor panel – did you use special adapters or simply screw them directly into the wooden panel?
Secondly, in your opinion, is there a maximum load that should not be exceeded on the PLATSA with casters to ensure stability and safety?
And
Nakar33 schrieb:
Make sure the casters are lockable to prevent unwanted rolling away.
sounds absolutely sensible to me, as unintended movement would indeed be problematic. What type did you use – industrial furniture casters or softer-locking casters more suitable for indoor use? I would appreciate further details to be able to realistically assess the whole setup.
Fitigu
6 May 2023 07:31
Regarding the question "Is it possible to equip Ikea PLATSA furniture with casters?" I can clarify the following:
PLATSA furniture is not originally designed to accommodate casters. The base structure is relatively thin, which makes direct attachment of casters difficult. For a secure installation of casters, it is advisable to mount an intermediate plate made of plywood or solid wood underneath the furniture to better distribute the forces.
About the casters:
- Casters with a minimum diameter of 50 mm (2 inches) and a load capacity of at least 40 kg (88 lbs) per caster are recommended.
- Lockable casters are essential to ensure stability.
A self-made modification only makes sense if the weight of the furniture and its contents are taken into account. Multiple attachment points are necessary so that the casters are evenly loaded and no warping occurs.
There are no official Ikea accessories for PLATSA casters, so the measures described above are the most practical option. Caution is advised to avoid compromising stability and build quality.
elgla
7 May 2023 18:08
I can imagine that the idea of equipping PLATSA elements with casters is very appealing to many, especially if you want to stay flexible. At the same time, I understand that these pieces of furniture were not specifically designed for that, which raises concerns about safety and durability.
I myself have considered the caster solution but have doubts about whether the furniture can withstand the stresses in the long term, especially if there are children or pets in the household.
If you do decide to go with casters, I would strongly recommend carefully checking this setup again once the furniture is in its final position. It might also help to add a lock mechanism on the furniture or the wall in addition to the casters to prevent tipping.
Sometimes you invest a lot of time and effort into such DIY projects, and in the end, a bit more stability turns out to be the best compromise between flexibility and safety.
Is there a specific reason for using casters in your case, such as frequent rearranging or cleaning?
