Hello everyone, I am considering adding casters to my IKEA Platsa system to have more flexibility for cleaning and rearranging. My question is: Is it possible to retrofit IKEA Platsa furniture with casters without compromising the stability or load capacity of the furniture? I would like to know which types of casters are suitable, whether there are official or unofficial solutions, and what to keep in mind during installation. Especially for heavier Platsa models, I’m interested in whether casters remain practical or if it’s better to completely rethink the design. Thanks in advance for your insights and experiences!
Hello Ondeo2! Your question is very well thought out. In general, IKEA Platsa furniture can be equipped with casters, but there are a few important points to consider. First, Platsa units are not originally designed for casters – meaning the furniture itself does not have pre-made mounting points. Therefore, you either need casters with mounting plates or have to come up with your own fastening solution.
Second, the load capacity of the casters must definitely match the maximum weight of the fully loaded piece of furniture – standard casters, such as those intended for light cabinets, often are not sufficient. Additionally, the stability of the furniture is important – the casters must not deform or compromise the frame under load.
My recommendation would be to choose casters with rigid mounting plates and ensure they are securely attached to the bottom frame or panel base during installation. Another option is to mount the furniture on a mobile plinth specifically designed for this purpose.
In conclusion: The idea is feasible but requires some craftsmanship and certainly high-quality casters rated for the weight.
Jeanbar schrieb:
The load capacity of the casters should definitely match the maximum load of the fully loaded piece of furnitureI would like to add here: The maximum load capacity of the IKEA Platsa is listed on the website as up to 30 kilograms per module, with a total load per section of about 60 kilograms. This corresponds to a relatively low mounting safety margin for casters meant to provide mobility.
It is also important to choose the type of casters carefully. Swivel casters are convenient, but with a heavy module they can tip under load or cause unwanted movement. Lockable casters are therefore the better choice to avoid wobbling.
Casters with a load capacity of at least 50 kilograms per caster are recommended to ensure safety margins and prevent material stress.
Mounting the casters directly to the bottom of the Platsa box is possible, but care must be taken that the structure is not weakened as a result. Ideally, the casters should be attached to a sturdy base or a wooden frame that distributes the weight evenly.
Ondeo2 schrieb:
My question is: Is it possible to retrofit IKEA Platsa furniture with casters without compromising the stability or load capacity of the furniture?Yes, it is! I personally upgraded my Platsa with casters, and it worked really well! 😄 The key is to use sturdy casters with metal fittings; otherwise, you might be surprised if the casters tear out soon. I used four casters per module – two of them lockable, so everything stays securely in place when it’s not being moved.
A tip: choose casters with a rubber coating to prevent floor scratches and ensure smooth movement of the furniture. Also, be careful when drilling and screwing in the spots where you attach the casters – it’s best to pre-drill using a hand drill first to protect the material.
Moreover, the furniture hardly wobbles as long as you don’t overload it and mount the casters properly. So: go for it, I find it really practical!
GAGRAHAM schrieb:
I upgraded my Platsa with casters myself, and it worked perfectly! 😄Wow, that sounds really great! I was just going to say that it’s definitely a nice solution, especially if you move it around often or want to clean the floor underneath.
A small tip from me: Make sure to choose high-quality casters and avoid the very cheap ones from big-box stores. Under load, those are often unstable and their plastic axles tend to break quickly.
Also, when assembling the Platsa series, it’s important that the tabs connecting the modules don’t allow any rolling movement. Otherwise, it can become wobbly when you install casters underneath.
Good luck with your project!
