ᐅ Is it possible to reinforce IKEA HEMNES furniture by adding baseboards or moldings for extra stability?
Created on: 1 Nov 2021 14:07
moritz7Hello everyone,
I am planning to get an IKEA Hemnes furniture piece, but I am a bit skeptical about whether it is really stable enough, especially if it will be loaded more heavily or placed in a frequently used room. Therefore, my question is: Is it possible and advisable to add additional baseboards to the IKEA HEMNES furniture to increase its stability?
I do not mean just an aesthetic adjustment, but an actually positive structural effect—for example, baseboards attached to the lower part of the cabinet that fix the furniture firmly to the floor and prevent wobbling. Does anyone have experience with such modifications, what materials would be suitable, and whether the connection between the baseboard and the furniture needs to be executed strongly enough to really stop the furniture from moving?
I appreciate any experience-based or expert opinions!
Hey moritz7,
you have a great idea! 🙂 Baseboards under the HEMNES furniture can really make a difference, especially if your floor isn’t perfectly level. I’ve done this myself, and I can tell you: it works really well and the piece of furniture suddenly feels much more stable.
I used simple MDF mouldings and attached them to the cabinet bottom with small wooden dowels and wood glue. It’s important to adjust the mouldings to fit the floor before fixing them, so they make full contact. After that, you can paint the mouldings nicely, and it almost looks like they belong there.
Just give it a try—you’ll be impressed! Don’t forget, the mouldings need to sit flush along their entire length, or it won’t help much.
fepau schrieb:
Baseboards under HEMNES furniture can really make a difference, especially if your floor isn’t perfectly level.Interesting approach, but it’s important to differentiate: baseboards used for stabilization only work if the attachment between the baseboard and the furniture is strong enough to handle forces that might otherwise cause the furniture to tip over.
I doubt that simple wood glue and dowels provide lasting increased stability—especially if the furniture is moved or loaded. The connection could come loose or get damaged. Additionally, the baseboard can only compensate for uneven floors if it is not too rigid. Otherwise, the furniture frame itself would be stressed by any wobbling of the baseboard.
Does anyone have concrete experience with a permanent mechanical connection—such as screws through the baseboard into the frame? Or is this mainly an aesthetic solution with only marginal stability improvement?
I would like to offer a somewhat more technical perspective here. In general, any furniture carcass can be made more stable with additional braces or baseboards, as long as the connections are executed solidly.
Regarding the IKEA HEMNES: The furniture is made of solid wood, but its stability mainly relies on the vertical side panels and cross braces. Baseboards can help by connecting the carcass at the bottom and protecting it against twisting.
Recommendations for implementation:
- Use sturdy brackets or screw connections instead of just glue and dowels.
- The baseboards should be firmly connected to both the carcass and the floor, if necessary with floor screws (pay attention to the flooring!).
- Be careful not to transfer too much load onto the baseboards as load-bearing elements, as this could cause the furniture to warp.
In summary: Yes, it is possible, and it can make sense on uneven floors or with strong lateral pressure, but it requires more than simple strips – solid mechanical connection is essential.
Danial schrieb:
Does anyone have direct experience with a permanent mechanical connection—like screws going through the trim into the cabinet frame? Or is that mainly a visual detail with only a slight increase in stability?Hi Danial, yes, I used small screws into the wood. Combining screws with glue provides excellent hold—the furniture doesn’t wobble at all anymore! Of course, it requires a bit more effort, but the improvement in stability is definitely worth it 100%!
klo40 schrieb:
The baseboards should be firmly connected to the cabinet and the floor, if necessary with floor screws (pay attention to the flooring!).Absolutely correct! On carpet, this is more challenging, so you can use rubber feet under the trim to prevent the furniture from sliding. On hardwood floors or tiles, a solid connection works well, also with screws that can be filled afterward for a perfect finish.
To add a technical perspective:
IKEA HEMNES furniture is designed for standard loads; adding an additional baseboard can actually increase stability, especially against lateral tipping forces.
It is important that:
- The baseboards are manufactured with precise measurements to ensure consistent contact with the floor.
- The connection between the baseboard and the furniture is firm but not overly rigid. A rigid connection increases stress on the furniture frame joints and can cause cracks.
- Baseboards should not only be doweled but also screwed in to ensure long-lasting stability.
- A better alternative may be a combination of slightly flexible feet with adapted floor skirting to compensate for stresses.
In conclusion: Yes, it is possible and advisable if implemented correctly from a technical standpoint. However, a purely decorative baseboard does not provide any noticeable stability improvement.
