ᐅ Is it possible to equip Ikea Brimnes doors with soft-close mechanisms?
Created on: 27 Sep 2024 08:37
nicky7
nicky7
27 Sep 2024 08:37
I am planning to equip the doors of my Ikea Brimnes wardrobe with soft-close hinges because the slamming of the doors, especially in the morning, is quite disturbing. Now my question is: Is it technically possible to modify the existing Brimnes doors to fit soft-close hinges?
I have already noticed that Brimnes does not offer a soft-close version from the factory. Therefore, I would be interested in practical tips or experiences on how to retrofit soft-close hinges or alternatively modify the doors without negatively affecting their stability or function.
Are there specific hinge systems that are compatible, or would it be necessary to make adjustments to the cabinet frame or the doors?
Thank you in advance for your expertise!
SETHBLA
27 Sep 2024 09:03
Yes, that is possible. You can purchase soft-close hinges that match the standard dimensions of the Brimnes doors. It is important that the hinges are properly adjusted; otherwise, the soft-close function will not work satisfactorily.
Lorukeo
27 Sep 2024 10:22
When retrofitting soft-close hinges on Ikea Brimnes furniture, the following technical aspects should be considered:
- The Brimnes doors are equipped with simple cup hinges without damping.
- Most standard soft-close hinges are compatible, provided they are designed for a 35 mm (1 3/8 inch) hole diameter and spacing.
- It is advisable to remove the doors and replace the old hinges completely.
- Some users report that the doors are thin, so a soft-close hinge with a low installation depth volume is recommended.
- Any existing drill holes should be inspected and, if necessary, filled with wood filler if different drilling points are required.
Conclusion: Retrofitting is technically possible but requires some DIY skills and precise measurements.
fredle
28 Sep 2024 14:46
Hello nicky7,
Here is a brief guide on how to install the soft-close function on your Brimnes doors:
1. Selection of hinges: Purchase soft-close cup hinges with a 35mm (1.4 inch) cup hole diameter that are compatible with flat doors.
2. Removing the old hinges: Take the doors off, loosen all screws, and carefully remove the old hinges.
3. Checking the drill holes: Brimnes doors have standard drillings. If the screw holes do not align, fill them with wood filler.
4. Installing the new hinges: Position the new soft-close hinges according to the drill holes, ensure they are properly aligned, and secure the screws.
5. Adjustment: After installation, fine-tuning the door is essential. Most modern soft-close hinges offer three-dimensional adjustment options.
6. Test: Close the door slowly several times to ensure the damping works properly and the door closes evenly.
A common mistake is overtightening the hinges or misaligning them, which can affect functionality. Also, installing soft-close mechanisms on doors that are too thin can be difficult, so make sure to check this before purchasing.
If you have any further questions, I’m happy to help.
koduga
29 Sep 2024 07:18
fredle schrieb:
5. Adjustment: After installation, fine-tuning the door is essential. Most modern soft-close hinges offer adjustment options in three dimensions.
I can only confirm that. Especially with IKEA furniture, even a slight misalignment during assembly can seem more significant than expected and can be frustrating.
I recently tried to modify the Brimnes doors myself and had to readjust because the doors didn’t close properly otherwise. A tip: work slowly and test each door individually at the end to avoid unnecessary frustration.
Additionally, I want to mention that retrofitting requires some basic DIY skills. If you’re unsure, it might be worth asking for help from an experienced friend or a professional tradesperson. This way, no doors get damaged.
Kinbu
29 Sep 2024 19:57
Hello nicky7 and everyone interested,
I would like to add that besides the classic soft-close cup hinges, there are also so-called clip-on hinges with soft-close function that make retrofitting easier. Their advantages:
- They can be installed without removing the entire hinge.
- The clip system often allows for easier and faster adjustment.
However, it should be noted that Brimnes doors are quite thin (~15 mm (0.6 inches)), so the stability of the screw fastening can sometimes be limited. During installation, it is important to be careful not to cause cracks or breakout around the drill holes.
Summary:
- Retrofitting is possible with the right choice of hinges.
- Pay attention to compatibility with the door thickness.
- Precise adjustment is essential.
- It may be helpful to test with a sample hinge first.
If you like, I can also recommend specific manufacturers who offer polishing technology for thin doors. Just let me know!
