ᐅ Is it possible to dry out damp back panels in a KALLAX unit without replacing them?
Created on: 21 May 2020 08:17
Goben44
Goben44
21 May 2020 08:17
I have noticed that the back panels of my IKEA KALLAX shelf have become damp in some places. The shelf is usually kept in a fairly dry environment, but moisture seems to have accumulated over time. My question to the community is:
_Is there a way to dry the damp back panels of the KALLAX without having to replace them completely?_
I am especially interested in the best approach to do this so that the material is not further damaged and the back panel remains stable and functional afterward. Does anyone have experience with suitable drying methods or treatments?
I would prefer not to take the whole shelf apart unless absolutely necessary.
Thanks in advance for all tips and advice!
RAGUGI
21 May 2020 08:25
Simply remove the back panel, place it in a well-ventilated area, and allow it to dry completely. If possible, carefully assist the drying process with a hairdryer set to a low temperature. Be cautious not to apply too much heat, as this can warp the wood. Afterward, you can check if the back panel is still intact.
laume
21 May 2020 10:42
Hello Goben44,
The issue of moisture on KALLAX back panels comes up frequently, especially when the furniture is placed in more humid rooms. It is important first to identify the source of the moisture – and then to thoroughly dry the back panel.
RAGUGI schrieb:
carefully assist with a hair dryer on low heat
That is a good tip, but I would additionally recommend not only drying the surface but allowing the material itself to dry completely to prevent mold growth.
One method is to move the back panel to a warm, dry place with good air circulation – for example, a room with a dehumidifier. If the panel is only partially damp, absorbent cloths can also be used to remove residual moisture.
You might also want to check for any warping or damage, as prolonged moisture can affect stability. If there is none, it is likely that the back panel can be saved through gentle drying.
Good luck with the drying process, and please let us know if you have any further questions!
Laukau5
22 May 2020 14:36
I would like to approach this topic from a more technical perspective, as there are some important details regarding damp back panels in KALLAX units that can help avoid the need for replacement.
1. Material properties: The back panels of KALLAX are usually made of thinner high-density fiberboard (HDF), which can swell easily when exposed to moisture. It is important to note that even minor water penetration can lead to permanent deformation.
2. Drying steps:
- Carefully remove the back panel from the shelf without breaking it.
- Wipe both sides with an absorbent cloth to remove surface moisture.
- Then place it in a room with a temperature of at least 20-25 degrees Celsius (68-77°F) and good air circulation. A fan can help as well.
- Avoid direct sunlight or strong heat sources, as this can cause uneven drying and cracking.
3. After several days, the back panel should feel noticeably drier. Before reinstalling, make sure there is no residual moisture (check by hand touch or with a moisture meter).
4. If the panel is already significantly swollen, you can try to gently straighten it with a flat edge, but proceed with caution as the material may become brittle.
5. Alternatively, consider making or purchasing a replacement back panel made of a similar material.
Finally, one question: Where exactly is the shelf located? Sometimes addressing the source of moisture can help prevent long-term damage.
I hope this information is helpful!
relupa
23 May 2020 11:02
Hello Goben44,
I completely understand that you don’t want to take the whole shelf apart or replace the back panels right away. Moisture on furniture is always stressful because of the risk of mold or unpleasant odors.
I once had a similar situation with a shelf where the back panel had gotten a bit damp. What helped me back then was a combination of calmness and patience – first, I removed the back panel and then placed it in a warm, dry area with good ventilation. It was important not to act hastily or expose the material to overly hot air, as that would have made things worse.
laume schrieb:
really letting the material dry thoroughly to prevent mold formation
That’s true, I agree with that. And if you notice that the shelf is stable again afterward, you can carefully reinstall it.
Laukau5 schrieb:
Sometimes addressing the source of moisture helps prevent long-term damage
Exactly, it might also be worth taking a closer look at where the shelf is located. A little tip from me: a dehumidifier or even simply ventilating the room can often work wonders without much effort.
I hope your shelf lasts a long time and the back panels won’t need to be replaced! 🙂
