ᐅ Is it possible to adapt IKEA BRIMNES furniture for use in the bathroom?
Created on: 22 Feb 2019 09:12
Laladi
Laladi
22 Feb 2019 09:12
I am currently considering whether the IKEA Brimnes furniture series, especially the dressers and cabinets, can be adapted for use in a bathroom. The furniture is basically made from wood-based panels with a plastic coating but is not specifically designed for humid environments. My question is: What measures are necessary to treat or modify the BRIMNES furniture so that it can withstand long-term exposure to high humidity and occasional water splashes in a bathroom?
I am particularly interested in whether there are special paints, sealants, or simple protective methods (such as silicone sealing) that can protect the material. I am also wondering if the hinges and other metal parts could be damaged by the moist environment and if there are recommendations for alternative fittings.
I look forward to your experiences and tips – maybe someone already uses BRIMNES in the bathroom and can share what they did and whether it holds up!
Thank you and best regards!
U
usron
22 Feb 2019 11:03
Hey Laladi! Great idea to use the BRIMNES in the bathroom! 😄 I think it can look really cool, and with the right techniques, it will hold up well there!
It’s important to seal all edges and surfaces with a good waterproof varnish – preferably acrylic or polyurethane varnish, as those are really resistant to moisture. You can replace the hinges with stainless steel or brass ones to prevent rust.
I’d also recommend sealing all joints with silicone, especially in areas frequently exposed to water.
Just go for it, don’t be discouraged! And if you need any help, just reach out here! 🚀
blagla
22 Feb 2019 12:47
usron schrieb:
It is important to seal all edges and surfaces with a good waterproof varnish – preferably acrylic or PU varnish, as these are truly resistant to moisture.
I would like to agree with this, but with the addition that IKEA BRIMNES furniture is primarily made of particleboard, which can swell if it comes into direct contact with water, even if the surface is sealed.
Therefore, careful sealing of the furniture is essential, including:
- Multiple layers of PU varnish on all visible surfaces and edges
- Use of moisture-resistant fittings that are corrosion-resistant
- Careful placement, for example, not positioning the furniture immediately next to the shower
It will never be 100% waterproof, but these measures can significantly extend the lifespan.
kyledeo
22 Feb 2019 13:30
Simply coat all surfaces with waterproof paint.
Replace hinges with stainless steel ones.
Add rubber seals to keep water out.
Ensure no direct water contact and maintain good ventilation.
kau56
23 Feb 2019 08:55
Hello Laladi,
to answer your question in more detail: The BRIMNES furniture is generally not designed for damp rooms. The material, especially the particleboard, is sensitive to moisture and can swell if it stays wet for extended periods.
However, there are ways to modify the furniture if you are willing to invest some effort:
- Sealing with special moisture-resistant paint or multiple layers of polyurethane (PU) varnish, including on the back, underside, and edges.
- Ensuring no puddles of water form, so be careful with placement.
- Replacing the standard hinges with rust-resistant versions, such as stainless steel.
- Adding extra seals on the edges, for example with sanitary silicone, to prevent water ingress.
- For better protection, you could even raise the furniture slightly off the floor (e.g., by placing it on small feet).
Still, you should keep in mind that this furniture will not perform as well as specially designed bathroom furniture. But with careful treatment and regular checks, it can be a practical solution.
If you decide to do it yourself, I recommend testing the paint adhesion and durability on a small area first.
Best regards!
trevor
24 Feb 2019 10:19
kau56 schrieb:
There are definitely ways to retrofit them if you’re willing to put in some effort:
I also think it all sounds doable, but don’t underestimate the damage moisture can cause. My recommendation is to play it safe and treat the furniture with a waterproofing product that also protects against mold.
In addition, good ventilation in the bathroom is extremely helpful. A small fan or simply opening a window is invaluable; otherwise, even the best sealant won’t help.
Have fun with your project – and remember, improvising here can actually be a lot of fun! 😉
