ᐅ Is it possible to change the color of IKEA BRIMNES furniture after purchase?
Created on: 30 Nov 2024 14:23
reinald
Hello everyone, I recently purchased some furniture from the IKEA Brimnes series and am now considering changing their color. My specific question is:
Is it basically possible to treat the surfaces of the BRIMNES furniture so that they get a new color permanently, without causing any damage to the furniture from painting or coating?
I am particularly interested in the material properties, whether it is possible to do the work myself (e.g., sanding, priming, painting or coating), and how the results turn out in terms of durability, appearance, and maintenance.
Does anyone have experience or recommendations, maybe even tips on suitable paints or techniques? I want to avoid the furniture becoming unattractive later on due to warping, chipping, or blistering.
nubar
1 Dec 2024 10:42
One aspect that is often underestimated is the flexibility of the material surface. Melamine coatings are hard and brittle, which can cause the altered surface to develop cracks when exposed to temperature or humidity fluctuations.
Therefore, it is advisable to:
- Create and test small sample areas before starting work.
- Use water-based paint to avoid brittle paint films.
- Place the furniture as evenly as possible in the room after treatment to minimize effects caused by drafts or heating.
If you plan to alter the furniture long-term, professional clear coating or foil application could also be alternatives, although they involve different levels of effort.
reinald
1 Dec 2024 11:11
nubar schrieb:
If you want to change the furniture long-term, a professional clear coating or wrapping could also be an option
That sounds interesting – do you have any experience with wrapping on Brimnes or similar furniture? I ask because I want a more unique color (for example, matte dark blue) and I'm unsure whether paint or wrapping would offer better durability.
flo-Theres
1 Dec 2024 12:36
reinald schrieb:
I’m asking because I want something a bit unusual for the color (e.g., matte dark blue)
Matte dark blue can be achieved quite well with spray paint or regular paint. Wraps are usually available in glossy or semi-matte finishes, but they can be very durable and eliminate the risk of paint chipping.
One advantage of a wrap is that it covers imperfections well and is generally easier to replace than a layer of paint.
If you want to do it yourself, paint might be more flexible when you’re aiming for exact shades.
juMira46
2 Dec 2024 08:49
I really like how detailed you are about materials and techniques here! A practical tip:
- Make sure to clean dust off thoroughly before painting, otherwise you’ll end up frustrated by small imperfections later.
- When sanding, don’t apply too much pressure, or the fibers may start to lift unexpectedly.
Palenar schrieb:
Paint systems based on acrylic or polyurethane are excellent choices
I completely agree. They might be a bit more expensive, but the finish and durability are definitely much better.
Good luck with your makeover – this will definitely give your BRIMNES combination a unique look!
Kinbu
2 Dec 2024 09:55
juMira46 schrieb:
Don’t apply too much pressure when sanding, or the fibers might start to stand up.
Exactly, this especially happens with chipboard edges. That’s why it’s best to work the edges very carefully with fine sandpaper and then wipe them down with a damp cloth.
Also, if you’re using very pigmented paints, make sure to apply several thin coats before the final layer to avoid unsightly streaks or color variations. Patience really pays off here.
