ᐅ Is it common for Malm beds to start squeaking after a while?
Created on: 9 Feb 2021 08:12
Sinsar
Hello everyone, about a year ago I bought an IKEA Malm bed and have been using it regularly since then. However, for the past few weeks, I have noticed that the bed squeaks quite a bit when turning or moving, which is somewhat annoying. I’m wondering if this is normal for Malm beds or if it could be due to material fatigue or assembly errors. The squeaking usually comes from around the joints between the frame and the slatted bed base, and it happens regardless of the time of day or humidity. Has anyone had similar experiences? Are there any proven methods to fix the squeaking? Thanks in advance for your feedback and tips!
Joshbe
9 Feb 2021 12:55
I would like to add that when using MDF, moisture can particularly affect squeaking. If the bedroom becomes more humid or drier, the material changes slightly, which can increase friction and thus cause noise. Therefore, avoid significant fluctuations in humidity.
Additionally, some screw connections in Malm are designed to be quite tight. If you press the parts very firmly together during adjustment, this can increase stress and cause noise.
LEOIX
9 Feb 2021 13:42
Have you noticed that many people assume wood and MDF furniture are inherently noisy? To me, this often sounds more like cheap product design or assembly errors.
onMarcos schrieb:
Assembly: If not built exactly according to the instructions, parts can be under stress and cause noise.
In my opinion, that’s the core issue. Proper assembly is essential. And if you buy cheap furniture, you have to expect such problems. The bed system isn’t as sturdy as some believe.
Khalil
9 Feb 2021 15:07
LEOIX schrieb:
The bed system isn’t as sturdy as some might think.
Well, you can’t really say that so generally! I’ve had a Malm bed for three years without any serious issues, just the occasional squeak that can easily be fixed with a bit of maintenance. You just have to love your furniture and be willing to spend some time on it. :-)
kenkeo
9 Feb 2021 16:20
Hello everyone! I find this discussion really helpful. I had the same problem with my Malm bed! In my experience, it also helps to completely remove the slatted frame from the bed frame, clean the support points, and add felt pads. After that, I checked and tightened all the screws, and the squeaking was gone! Malm is great, as long as you take a little care of it! 🙂
Sinsar
10 Feb 2021 09:33
Thank you for all the very helpful tips so far!
Last night, I checked and tightened all the screws. I noticed that at one corner, the frame joint has a slight play, probably due to a slightly worn thread. That was likely a cause of the squeaking.
@onMarcos: I find your idea of using a wax stick interesting. Do you have a recommendation on which products work best for this? And are there any risks if you apply too much?
@liskar and Joshbe: I can understand the humidity factor, as it has been very dry at night over the past few weeks. I will keep an eye on whether the squeaking changes depending on the weather.
O
onMarcos
10 Feb 2021 10:47
Sinsar schrieb:
@onMarcos: I find your idea with the wax stick interesting. Do you have any recommendations on which products work best for this?
Sure! I recommend beeswax or a special furniture wax block, which you can find at most hardware stores or furniture shops. Simply take a small amount of wax with a cloth and apply a thin layer to the screw threads or wooden joints.
Sinsar schrieb:
Are there any risks if you apply too much?
Yes, applying too thick a layer of wax can attract dust or make the screws slippery when tightening. Therefore, it’s better to work in thin layers and remove any excess wax after tightening. It is important to make sure the surfaces to be treated are clean and dry before application.
