ᐅ Is it normal for Ikea Hemnes furniture to creak or squeak during assembly?
Created on: 9 Jan 2022 19:37
ineslu
Hello everyone, I recently assembled an Ikea Hemnes wardrobe and noticed that the doors sometimes creak or squeak slightly when moved. I’m wondering if this noise is normal for the Hemnes model or if it might indicate loose installation, insufficient lubrication, or possibly material issues. Has anyone else experienced something similar with the Hemnes? If so, how did you resolve the problem? Are there any specific tips for assembly or maintenance to reduce the noises? Thanks in advance for your feedback!
LENNAU
10 Jan 2022 17:05
[@ineslu] A controlled indoor climate is definitely better for wooden furniture. A relative humidity of about 40-60% reduces stresses in the wood that can cause creaking. Regarding the hinges, careful disassembly and renewing the lubrication is not a problem and does not affect the warranty, as long as the parts are not damaged. Important: Use suitable lubricants such as silicone spray or furniture wax, not oil-based or sticky substances. Ikea itself does not provide any particularly forbidden maintenance instructions for Hemnes, so you are on the safe side with clean, careful work.
jordanvin
11 Jan 2022 10:44
A Hemnes wardrobe is great, but when it comes to squeaking, it can get really annoying! 🙂 I had creaking with mine too, and it turned out a few screws were loose. After a quick pass with the screwdriver, everything was quiet again. So, keep your spirits up—this is a common issue and often fixed easily with a bit of maintenance. Good luck!
GALENKU
11 Jan 2022 16:13
Squeaking is often a result of assembly issues. Check the screws, clean and lubricate the hinges. If it still squeaks after that, there might be a defective part.
PECLARISSA
12 Jan 2022 12:26
I think a little quiet creaking from wooden furniture is almost like a small living thing making itself noticed 😉. But joking aside – if it’s annoying, simple steps usually help: check the screws, lightly sand any wooden areas, and lubricate all moving parts well. Hemnes is a sturdy piece, so it’s worth taking care of it. And if nothing helps, Ikea’s customer service is generally very straightforward. Good luck, and hopefully your cabinet will be completely silent soon!
