ᐅ Is it advisable to place Kallax units on legs instead of directly on the floor?
Created on: 26 Apr 2022 09:13
marjan
Hello everyone, I have a question and would like to hear your opinions: Do you think it makes sense to put the IKEA Kallax shelving unit on legs instead of placing it directly on the floor? I’m referring to those small wooden or plastic feet that you screw or stick under the unit to raise the furniture slightly. I’m mainly interested in aspects like stability, ease of use, cleaning, and appearance. Could placing it on legs also affect load capacity or the ability to slide something under the shelf? I’d really appreciate it if some of you who have tried this could share your experiences. Thanks in advance!
marjan
26 Apr 2022 10:02
Thank you for your previous answers! @nubar, you mentioned the load from books and decorations. Have you recommended or used specific legs that can withstand such weight? I am also interested in whether placing the shelf on legs increases the risk of tipping, for example, if the legs are narrow.
DEOLAU
26 Apr 2022 10:05
I use small, wide wooden feet under my Kallax. They slightly improve stability because they raise the base a bit and compensate for uneven surfaces. I have never experienced any tipping, even though the feet are about 2 cm (1 inch) high.
Jimte
26 Apr 2022 10:13
It is important to ensure that the feet are firmly in place and evenly distributed. I chose plastic feet with a bit of texture – this prevents the shelf from slipping and keeps it stable. Tilting is not an issue for me.
Rashadmeo
26 Apr 2022 10:18
One more advantage: It's great that if you choose uniform color and material for the legs, you get a completely new look! :-) I went with black wooden legs, which perfectly match the dark Kallax, and it looks really elegant!
Espen
26 Apr 2022 10:23
If you place the shelf on feet, you need to consider the height. Will it still fit under other furniture or into niches? If not, it is better to place it directly on the floor.
FELOTAU
26 Apr 2022 10:27
Sometimes I have also seen angled legs that make the shelf unit look almost like a sideboard. This gives the Kallax furniture a bit more elegance! 🙂 Of course, you need to make sure the legs are securely attached; otherwise, it will wobble.
