ᐅ Is it advisable to glue Ikea BRIMNES shelves together?
Created on: 31 Jan 2017 13:07
Rilutu
Rilutu
31 Jan 2017 13:07
Hello everyone, I am currently considering whether it makes sense to glue Ikea Brimnes shelves. The reason is that I noticed with one of my shelves that the individual parts shift slightly over time, which could affect stability. Now I am wondering if gluing the parts—for example, the back panels or the joints—is recommended to strengthen the construction in the long term, or if it might cause disadvantages, such as during transport or when disassembling later. Does anyone have experience or specific recommendations regarding durability and potential damage when using adhesive? What type of glue is suitable for chipboard and bonding these shelves? Thanks in advance for any constructive feedback!
Timofa
31 Jan 2017 14:52
Hey Rilutu, interesting question! Here’s my suggestion: gluing can actually make sense for a BRIMNES shelf, especially if you have the shelf fixed firmly against a wall and don’t plan to move it around often. 😊
- A commercial adhesive or special wood glue works well because it remains flexible and doesn’t leave large marks.
- I once reinforced a shelf with a small amount of glue at the joints, and it has felt more stable ever since. Of course, it gets harder to take the shelf apart during a move.
Important: don’t overdo it with the glue, or it might become a real pain to disassemble later. 😉
But if your main goal is stability, I’d recommend at least gluing the back panels. They then really act like a solid cross-brace and make the whole structure much more durable.
Sergio49
1 Feb 2017 09:18
Regarding the question about gluing the Ikea BRIMNES shelves, here is an objective assessment:
Gluing can increase stability by reducing movement between the individual panels, making the overall construction stiffer. This is especially important for the back panel, which serves a load-bearing function and minimizes shifting and sliding.
A suitable wood glue (PVAC glue) is recommended, as it adheres well to chipboard with a melamine coating, provided the bonding surfaces are lightly sanded and degreased beforehand. Aggressive adhesives, such as superglue, should be avoided because they can damage the surface or cause brittleness.
However, if the shelf needs to remain flexible—for example, due to frequent relocations—gluing is not advisable, as it destroys the ability to disassemble. For permanent installations, such as fixed furniture in living spaces, gluing as reinforcement is generally sensible.
In summary: Gluing can improve durability but reduces flexibility during transport. The decision should be based on individual usage needs.
Johnnybe
1 Feb 2017 11:43
Gluing only makes sense if you don’t plan to take the shelf apart again.
For sturdier shelves: apply wood glue to the back panel and edges, then let it dry.
When moving, glue is more likely to cause damage than be beneficial.
Adhesive: wood glue is ideal.
dopite
2 Feb 2017 08:57
Rilutu schrieb:
Now I'm wondering whether gluing the parts – such as the back panels or the joints – is advisable to strengthen the structure in the long term, or if it might cause more problems
Very good question, because when gluing Ikea BRIMNES shelves there are important differences depending on the area:
- Back panel: Gluing here with wood glue can significantly increase stability, as the back panel acts like a cross brace that strongly limits lateral twisting.
- Side panels and shelves: Gluing is possible, but it increases the effort during assembly and when making changes later on. Depending on how often you plan to move or modify the shelf, this can be inconvenient.
- Glue selection:
- Wood glue (PVAC) works well for particleboard and creates a durable bond.
- Avoid contact adhesives or superglue – these can be harmful.
My advice:
1. Lightly sand the edges and remove any dust before gluing.
2. Apply the glue thinly to prevent excess from squeezing out at the edges.
3. Use clamps or suitable grips to ensure no gaps form after gluing.
If you plan to use the shelf permanently and don’t expect to disassemble it often, then gluing especially the back panel is a good idea to avoid future wobbling.
However, if you consider the shelf as furniture for flexible use, I would recommend against gluing.
