ᐅ Is IKEA PLATSA a long-term investment?
Created on: 29 Nov 2023 08:13
Gianluig68
Hello everyone, I am currently considering whether the IKEA Platsa system is a good long-term investment—specifically, if it is truly worth investing in these modular furniture pieces today for use over many years. I am particularly interested in the quality of the materials, how well the system holds up after multiple moves or renovations, and whether the flexibility of the system really justifies the effort and cost. It is important to me that the furniture remains sturdy, can be easily adapted if needed, and provides lasting satisfaction without having to make frequent replacements. Has anyone had experience with PLATSA over an extended period or can share insights on the workmanship, stability, and possible weaknesses? Are there differences between the various module types or versions that should be considered? Looking forward to your assessments and tips!
JONSON
30 Nov 2023 10:47
For use as a wardrobe and given the described size, Platsa is well suited. The drawers are designed for light to medium loads. If the drawer slides are properly maintained and well adjusted, they will last in the long term. It would be advisable to keep the option open to add more modules later.
A tip: Avoid using very heavy partitions to prevent unnecessarily increasing the weight of the construction. A sturdy but lightweight structure helps avoid stability issues.
lajudo
1 Dec 2023 07:58
The modular construction of PLATSA is well suited for long-term adjustments. As long as you check the screws after six months and then annually, you can ensure good stability. The material quality is sufficient for a mid-range standard.
bauku
1 Dec 2023 09:18
lajudo schrieb:
The modular construction of PLATSA is well suited for long-term modifications.
Absolutely! And remember: patience during assembly pays off! Better to screw things twice than end up with wobbly furniture later. I’m always happy to share the flexible adjustments I make with my PLATSA. Definitely a great long-term solution! :-)
