ᐅ Is the Ikea Pax system also suitable for storage in a garage?
Created on: 27 Aug 2024 09:17
finniganfu
finniganfu
27 Aug 2024 09:17
I’m planning to use the Ikea PAX wardrobe not in a living area as usual, but as a storage solution in my garage. Although my garage is dry, temperatures can drop below 0°C (32°F) in winter and can also get quite high in summer.
My question is: Is an Ikea PAX system, with its typical wood-based panels and particleboard carcass, suitable for use in a garage, especially when it comes to long-term storage with minimal visible damage or loss of function?
I’m interested in the effects of temperature fluctuations and humidity, as well as the stability of the unit with frequent opening and closing under these conditions.
Do any of you have experience using PAX in garages or similar unheated spaces? Or would you generally advise against it from the start and recommend alternative solutions?
Thank you in advance for your insights!
Basically, I’m looking for an affordable but durable solution for organization and storage in the garage and am wondering if the PAX wardrobe is really the right choice here.
sanjan
27 Aug 2024 11:35
I would definitely not use PAX wardrobes in an unheated garage. The engineered wood material does not tolerate moisture well and can swell.
Metal shelving or plastic systems would be better, as they handle moisture and temperature changes more effectively.
Domau0
27 Aug 2024 14:58
There are indeed several important factors to consider when using Ikea PAX wardrobes in a garage.
First: The materials used. PAX carcasses are usually made from particleboard with a melamine coating, which works well indoors but is not very resistant to moisture and temperature fluctuations. In a garage, where relative humidity can often exceed 60%, there is a risk that the boards may warp or swell. Damage can develop over months or years, depending on how well ventilated and dry the space is.
Second: Temperature. The significant fluctuations you mentioned (below freezing in winter, high heat in summer) cause the materials to expand and contract. This can loosen screws and affect stability.
Third: Usage. Frequent opening and closing increases mechanical stress. If hinges, fittings, and runners are not sturdy enough, they will wear out more quickly.
My advice: If you want to use PAX in the garage, first secure the area as much as possible against moisture. Good ventilation, possibly a dehumidifier, and regular inspections are essential. Additionally, I would recommend using doors with more robust hinges and protecting the cabinet base with water-resistant measures (e.g., a waterproof underlay).
Alternatively, you might consider installing the PAX units within a protective enclosure or a small storage room, where the air conditions are more stable.
I am also curious: What exactly do you want to store in the garage? The type of items stored could change the recommendation.
I hope these detailed thoughts help you!
lyndon
28 Aug 2024 08:52
Domau0 schrieb:
First: The materials used. PAX carcasses are usually made of particleboard with a melamine coating, which works well indoors but is not very resistant to moisture and temperature fluctuations.
This is a very important point. I would add that while the coating provides some protection, it is not a complete barrier. Moisture usually penetrates the material through edges and carcass joints.
- For a garage, products made of metal or powder-coated steel shelving are more suitable.
- If PAX is still used, it is essential to ensure dry conditions.
Additionally, it is advisable to regularly oil or check hinges and fittings, as they might rust or become stiff more quickly due to temperature changes.
Overall, I see PAX in the garage as possible, but with significant limitations and necessary maintenance.
nubar
29 Aug 2024 19:04
finniganfu schrieb:
Are there any experiences here with PAX in garages or similar unheated areas? Or would you rather advise against it from the start and recommend other solutions?
I had PAX myself in a somewhat insulated garage. At first, everything looked fine, but after two winters noticeable warping and slight discoloration appeared on the lower cabinet boards, probably due to rising moisture from the floor and occasional condensation.
My recommendation: If you cannot heat or ventilate the space and moisture is underestimated, PAX is not a good choice. Don’t expect long durability—more like 2 to 3 years if you’re lucky.
Alternatively, galvanized metal shelving is better since it resists rust and moisture. It often costs a bit more but lasts significantly longer and is a better option for garage storage.
Question: How is the ventilation in your garage?
