I am currently considering whether the Ikea Brimnes furniture series is suitable for use in wet rooms. Specifically, I am interested in whether the surfaces and materials of Brimnes – especially the dressers and cabinets – offer enough moisture resistance to be installed in a bathroom, for example, without being damaged by water vapor, splashes, or high humidity.
I understand that the furniture is mainly made of particleboard with a foil coating, but how does this hold up in practice? Do any of you have experience or recommendations on whether Brimnes can actually be used long-term in wet rooms, or if it is better to choose specially designed moisture-resistant furniture?
I look forward to your assessments and, ideally, practical advice on this topic.
Thanks in advance!
Thanks in advance!
Hello IXMAU,
to fully answer your question about the suitability of Ikea Brimnes furniture for wet areas, I would like to explain in more detail the material characteristics and their behavior in humid environments.
Brimnes furniture is mainly made of particleboard sealed with a thin foil coating. This foil provides some barrier against light moisture but does not offer full protection against variable humidity or direct water exposure.
The critical issue is that particleboard swells when exposed to moisture for extended periods. This can cause irreversible damage to the furniture structure, especially at edges and screw joints, which may not always be fully covered by the foil. Splash water, high steam, and condensation—common factors in bathrooms—can create such conditions.
Another aspect is the adhesion of the paint or foil: constant moisture can cause it to peel off, making the furniture look unpleasant and vulnerable.
If you still want to use Brimnes in a bathroom, I strongly recommend the following protective measures:
- Position the furniture in areas with minimal exposure to splash water
- Ensure regular ventilation and avoid direct contact with water
- Additionally, seal edges with silicone or special laminate edge adhesives
Of course, this does not replace proper moisture-resistant furniture but can be a practical interim solution depending on the exact location.
I’m also interested to know more about your planned installation site. Are there windows for ventilation? Is it a guest toilet or the main bathroom area?
Regards,
Filippo
Regards,
Filippo
Hello IXMAU,
From my experience, I would like to add that furniture made of particleboard, like Brimnes, is not ideal for long-term use in wet rooms.
As already mentioned, they are sensitive to moisture. Different materials swell, and even small damages to the surface foil can quickly cause problems.
However, if you only have a small bathroom or a guest toilet that is well ventilated and where water rarely comes into direct contact with the furniture, it can work – with proper care.
It is important to regularly check the furniture and act quickly at the first signs of moisture damage.
I have two Brimnes dressers in my guest toilet that have lasted almost three years – I specially sealed the edges with clear varnish and pay close attention to ventilation.
If anyone is unsure, I am happy to share tips on how to better prepare this type of furniture.
uslis47
uslis47
Filippo schrieb:
Brimnes furniture mainly consists of particleboard sealed with a thin foil coating. While this foil provides some resistance to light moisture, it does not offer full protection against fluctuating humidity or direct water exposure.You have identified the core issue very well. Allow me to explain this in more detail from a technical perspective.
Particleboard absorbs moisture because wood fibers are hydrophilic. The foil coating on Brimnes furniture is very thin and only offers superficial protection against splashes. Especially edges, drill holes, or joints are critical points where moisture can penetrate. When this happens, the boards swell and lose both their structural strength and visual quality.
Specific advice if you still want to use Brimnes in a bathroom:
- Place the furniture as far away as possible from direct water sources (e.g., not next to a shower or sink if there is no splash guard)
- Use silicone seals on edges
- Apply an additional sealant with water-repellent clear varnish or special furniture oils
- Ventilate regularly, especially after showering
Furthermore, if you want to be absolutely sure, furniture made with water-resistant MDF boards or solid wood with special coatings is better suited.
In conclusion, Brimnes is generally not intended for wet rooms. Under very controlled conditions and with preventive measures, it can work, but the risk of damage increases significantly.
LOGEMIN
