ᐅ Is temporary construction power worth it because it’s more cost-effective? Any experiences?
Created on: 28 Aug 2018 13:20
chrisw81
chrisw81
28 Aug 2018 13:20
there is already a working electrical connection at our property, meaning the distribution box, meter, etc. are all functioning. It would also be possible to install a high-voltage connection.
Is it advisable to have an electrician apply for and install a temporary construction power box here, or does that end up costing the same or more than just paying the regular electricity rates right away?
Christian
niri09
28 Aug 2018 13:22
Who installed the meter?
I don’t understand this question at all. The temporary construction power is needed by the trades until the utility company connects you to the grid, which happens in new builds once the windows and doors are installed.
Egon12
28 Aug 2018 13:26
The expensive part of temporary construction power is not the electricity itself but the box rented from the electrician.
In our case, I think it was about 3 euros per day.
Of course, the electricity cost depends on the amount used, but the electricity rate is the same whether it goes through a temporary construction meter or a permanent meter.
niri09
28 Aug 2018 13:31
The temporary power distribution box was provided by the shell construction company; the price included both the box and the electricity.
Lobster
28 Aug 2018 13:48
With us, the "hardware" is provided by the construction company and is not charged separately. Therefore, it does not matter to me which meter the electricity is supplied through.
The setup for the temporary construction power connection costs just under 180€ in Lower Saxony. A few kilometers away in Bremen, a multiple of that amount is charged.
chrisw81
28 Aug 2018 16:15
I don’t understand the question at all. The temporary construction power is needed by the trades until the utility company connects you to the grid. In new builds, this usually happens once the windows and doors are installed.
The distribution box and meter were installed by the previous owner to have electricity on the property (in the garage). Could I then use the existing distribution box/meter for the construction power? That way, I wouldn’t have to install or rent a temporary construction power box, right?
