ᐅ Is click vinyl flooring suitable for underfloor heating?
Created on: 13 Jun 2023 14:33
Bauherrin_987B
Bauherrin_98713 Jun 2023 14:33Hello,
we are currently deciding on the flooring for our new build and have a question regarding click vinyl flooring in combination with underfloor heating. I would like to hear your opinions and recommendations on this. Is click vinyl flooring suitable for use with underfloor heating? If not, what alternative flooring options would you recommend?
Thank you in advance
WilderSueden13 Jun 2023 21:54Bringing in an expert here is a bit of an exaggeration. Basically, almost all floor types are suitable for underfloor heating. Some conduct heat better (tiles), while others less so (thick floating parquet). Click vinyl falls somewhere in the middle. Vinyl itself conducts heat well, but the integrated backing board is less helpful. In the end, this doesn’t really matter. At first, we were also focused on choosing the floor based on its presumed suitability for underfloor heating. Luckily, we didn’t go with that approach.
X
xMisterDx13 Jun 2023 23:13No, that's not true; there are plenty of ways to get it wrong.
There are impact sound insulation layers that alone have a thermal resistance of 0.1 W/m²K. Then, an inexperienced person adds 14mm (about 0.55 inches) click laminate flooring on top, which quickly brings the total to 0.25 W/m²K—well beyond the recommended maximum for underfloor heating.
This can even be an issue with click vinyl flooring, as the impact sound insulation is often seriously underestimated.
There are impact sound insulation materials with a thermal resistance as low as 0.01 W/m²K—but they do cost a bit more.
X
xMisterDx14 Jun 2023 11:52Vinyl has good thermal conductivity; click-lock flooring can't be thick enough to prevent that. The crucial factor is impact sound insulation, as it is often completely overlooked in the planning or the cheapest option available is chosen.
