notmaksen15 Oct 2020 12:48Hello,
We are currently considering whether an air-to-water heat pump is economically sensible for a house that meets the 2016 Energy Saving Regulation. The energy demand for the house (145m² (1560 ft²) of living space excluding 22m² (237 ft²) of hobby room in the basement) was calculated as follows:
The plan is currently to install an air-to-water heat pump from alpha innotec. Ventilation for the living area will be through windows; no mechanical ventilation system is planned.
Is it advisable to rely on an air-to-water heat pump here, or would other energy sources be more economical?
Daniel-Sp15 Oct 2020 13:21Here Novelan (technically identical to Alpha Innotec), good efficiency, no technical issues.... But the key question is the design of the underfloor heating. It must be compatible with a heat pump.
T_im_Norden15 Oct 2020 14:42Is the house already built, or is it still under construction?
notmaksen15 Oct 2020 15:40@Bookstar: More loops => better?
@Daniel-Sp: How much does the underfloor heating need to match?
@T_im_Norden: The shell of the building is almost finished.
Daniel-Sp15 Oct 2020 15:57Maximum supply temperature in the planned design. Possible flow rate (minimum volume flow required by the heat pump must be provided).
