ᐅ Is a wooden beam ceiling strong enough to support heavy furniture?
Created on: 30 Aug 2023 18:38
Finch039Hello everyone, maybe I'm being a bit paranoid – a construction site does leave its marks.
However, we are currently in the process of ordering our furniture. Until now, I hadn’t really thought much about it, until I saw the weight of our wardrobe: a solid 450 kg (990 lbs). Adding clothes and everything else that will be stored inside, we’re probably looking at around 550 kg (1,210 lbs), spread over just 2.5 sqm (27 sq ft).
Then there’s the bed, which weighs about 150 kg (330 lbs), and with two people in it, that’s a total of around 300 kg (660 lbs). So, in our 15 sqm (160 sq ft) bedroom, we’re likely dealing with approximately 1 ton (2,200 lbs) of weight that the wooden beams need to support.
This makes me doubt the load-bearing capacity of our wooden beam ceiling. Although, I’m probably one of the first people who wouldn’t just place a regular wardrobe on the upper floor? Am I overreacting with my concern, or would it be wise to have a structural engineer take a look just to be safe?
How old is the ceiling?
The standard specifies a live load or imposed load for ceilings and structural elements of residential buildings of 150 to 200 kilograms per square meter (31 to 41 pounds per square foot) – evenly distributed over the surface.
If you want a reliable assessment, you need to consult a structural engineer. It’s not very expensive.
Our beams from 1921 are similar, I believe 22 cm (9 inches) high and 14 cm (5.5 inches) wide. They span up to 4.55 m (15 feet), resting on the central wall and running across the entire house at about 7.55 m (25 feet). We furnished our rooms normally without any special considerations—wardrobes, beds, and some shelves. However, I wouldn’t overdo it. According to an architect friend, very large solid wood wall cabinets, bigger aquariums, waterbeds, and similar heavy items should always be structurally checked first. It’s worth investing those few extra dollars.
It looks similar in our house (built around 1900); the total load on the surface likely won’t become a problem anytime soon. I would be more cautious if there is a high load concentrated at a specific point. For example, a wardrobe distributes its weight over several joists and is also located close to the wall. It’s different in the case of a wood-burning stove with storage elements, where the load is often concentrated on a relatively small area.
