ᐅ Is a low-pitched shed roof practical, or is a flat roof a better choice?
Created on: 5 Nov 2025 20:21
bauhonk
Hello dear forum,
For our newly planned house with two full stories (floor-to-ceiling height 3.25m (10.7 feet)) on a 14 x 12m (the house is positioned “crosswise” on the plot, so the 14m (46 feet) side runs parallel to the street), we still need a roof. Visually, we like a flat roof. However, there are also some drawbacks. Mainly, we want to install photovoltaic panels across the entire roof (south-southwest orientation), and a flat roof is said to require more maintenance and be more prone to problems. As a second option, we are considering a single-slope roof (shed roof) slanting from the street side to the back. I find the single-slope roof interesting because its construction is simpler (no complex waterproofing, for example), and since we need a tilt angle anyway for the photovoltaic system, we wouldn’t have to elevate the panels as much. The big disadvantage is the appearance—or rather, that the front of the house would have to be much higher than the back. We want to achieve a clear ceiling height of 2.8m (9.2 feet) on the upper floor and would lower the ceiling anyway, so we wouldn’t gain any extra space.
Even with a 5-degree slope, which according to what I’ve read does not really offer advantages over a flat roof (no “self-cleaning,” water or snow — if it comes again — cannot drain as well), there would already be a height difference of more than 1m (3.3 feet) over 12m (39 feet).
Here are my questions, and many thanks in advance to everyone who takes the time to think this through:
- From what roof pitch does a single-slope roof actually offer advantages?
- Is my “concern” about a flat roof justified?
- Doesn’t a flat roof also require a certain minimum slope?
- How much photovoltaic capacity (kWp) would I “lose” by elevating panels on a flat roof?
- What is the cost difference between a flat roof and a single-slope roof?
I’m very grateful for any (partial) answers. I’m a bit stuck.
derdietmar
7 Nov 2025 07:29
to clear up some misinformation in this topic:
  • Paragraph 34 does not specify any requirements regarding the roof shape. Rejecting a building permit / planning permission application for this reason is not allowed and will therefore always be overturned. The law is clear: only the size and position of the building in relation to neighboring structures are considered.
  • A photovoltaic system on a flat roof is not secured by penetrating the roof waterproofing. It is ballasted with weights resting on the flat roof.
  • A properly constructed flat roof on a concrete slab (bitumen vapor barrier, insulation, EPDM waterproofing, and optionally fleece with gravel or green roofing) will likely outlast the rest of the house. Earlier leaks almost always occurred due to a decayed roof caused by moisture from below.
A shed roof can be built, but in 90% of cases it ends up looking like a warehouse. Especially on buildings where it was chosen for cost reasons, whose volume is also rather “cheap.”
It is better to go with a traditional gable roof with a timber frame built by a carpenter.
nordanney
7 Nov 2025 08:15
derdietmar schrieb:
A shed roof is an option, but in 90% of cases it ends up looking like a warehouse. Especially on buildings where it was chosen for cost reasons, and whose overall shape is also rather "cheap."
As an alternative (to give the roof more character), I suggest a staggered shed roof. It works great with an open roof structure and extra windows.
ateliersiegel7 Nov 2025 09:12
From what roof pitch angle does a mono-pitched roof actually have advantages?
- Is my "fear" of a flat roof justified?
Water has a small head.
It’s quite simple:
The better the water drains, the lower the risk of leaks.
A horizontal surface must be completely watertight.
A 1° slope provides very little benefit.
A 45° slope is significantly safer.
Everything in between is somewhere in the middle.
derdietmar
7 Nov 2025 09:49
A flat roof typically has a slope of 2%, as defined by flat roof guidelines.
The slope on a flat roof is less about making the water flow and more about creating a defined low point. The drain is located at this low point. As long as there is no other lower point and all higher points are connected to this low point via a consistent slope, water will collect there and drain properly. In theory, a slope of 1% is sufficient for this.
The top floor ceiling must always be watertight (vapor-tight). This applies to every roof. In the case of a flat roof, the top floor ceiling also serves as the roof itself.
