ᐅ Is a low-pitched shed roof practical, or is a flat roof a better choice?
Created on: 5 Nov 2025 20:21
bauhonk
Hello dear forum,
For our newly planned house with two full stories (floor-to-ceiling height 3.25m (10.7 feet)) on a 14 x 12m (the house is positioned “crosswise” on the plot, so the 14m (46 feet) side runs parallel to the street), we still need a roof. Visually, we like a flat roof. However, there are also some drawbacks. Mainly, we want to install photovoltaic panels across the entire roof (south-southwest orientation), and a flat roof is said to require more maintenance and be more prone to problems. As a second option, we are considering a single-slope roof (shed roof) slanting from the street side to the back. I find the single-slope roof interesting because its construction is simpler (no complex waterproofing, for example), and since we need a tilt angle anyway for the photovoltaic system, we wouldn’t have to elevate the panels as much. The big disadvantage is the appearance—or rather, that the front of the house would have to be much higher than the back. We want to achieve a clear ceiling height of 2.8m (9.2 feet) on the upper floor and would lower the ceiling anyway, so we wouldn’t gain any extra space.
Even with a 5-degree slope, which according to what I’ve read does not really offer advantages over a flat roof (no “self-cleaning,” water or snow — if it comes again — cannot drain as well), there would already be a height difference of more than 1m (3.3 feet) over 12m (39 feet).
Here are my questions, and many thanks in advance to everyone who takes the time to think this through:
- From what roof pitch does a single-slope roof actually offer advantages?
- Is my “concern” about a flat roof justified?
- Doesn’t a flat roof also require a certain minimum slope?
- How much photovoltaic capacity (kWp) would I “lose” by elevating panels on a flat roof?
- What is the cost difference between a flat roof and a single-slope roof?
I’m very grateful for any (partial) answers. I’m a bit stuck.
A flat roof can be made quite watertight, but having photovoltaic panels installed directly on it—that means penetrating the roof membrane and effectively turning it into a sieve—does not sit well with me. I would design the roof membrane itself as a photovoltaic system from the start and consider watertightness the most important factor. When you stand in front of the house, you don’t really see the roof anyway. And after six weeks, you get used to the appearance.
Dahlbomii6 Nov 2025 10:21Thoughts to consider: Assuming the upper floor in both options gets a concrete ceiling, the shed roof will require an additional roof structure. The extra effort and costs for this are unnecessary as long as the attic space is not being used as storage or living space. Additional wall area (2m (6.5 feet) along the street side masonry plus insulation), windows, electrical work, stairs, etc., just to create a storage room → very expensive. If you raise the whole thing by 0.5m (20 inches) or 1m (40 inches), you get around 40–60m² (430–645 sq ft) of extra living space, which you may not need but will cause additional costs around 100,000€.
Therefore, the premise must be adjusted: the upper floor should not receive a concrete ceiling but directly the shed roof ceiling. Rooms with a height of 4.5m (15 feet) can look very stylish, or you could install a dropped ceiling in the rooms facing the street. Whether you find this appealing from the inside is for you to decide; from the outside — especially from the street view — I would consider it less attractive. Cost-wise, it will likely be slightly more expensive.
Regarding photovoltaics: a luxury problem! Mounted flat on the shed roof, you can achieve about 34kWp; with tilted mounts, around 27kWp. The inverter will be limited to 30kW, so the energy loss due to alternating mounting is slightly higher but, in my view, negligible. If necessary, vertically mounted photovoltaic modules can be integrated on the south-facing parapet for low winter sun angles.
Development under Section 34 is often misunderstood and sometimes seen as a “free pass,” but it actually means quite the opposite: legal uncertainty that should be resolved through a preliminary building inquiry. The misconception that a general contractor’s draftsman—whether or not an architect is involved—will automatically correct any errors while tracing the client’s self-made plans in the same step simply because of their professional experience is another misunderstanding. This applies only partially: they remove obstacles to approval. The mistakes remain in place at the employer’s request, so as not to bruise the pride of the self-planning architect. There is nothing better for a contractor than when the client is also the planner, as complaints about poor workmanship can then be directed back to them. Liability ultimately falls back on oneself, great. A freelance architect carries professional liability insurance; for “necessary architectural services” provided by a self-certified master mason, there is none.
For your clumsiness, it makes no difference whether you ask about the roof shape before starting planning (instead of first agreeing on the basics) or mistakenly consider it a final detail after you are already “semi-final” with your counting rhymes at the end. Opinion polls (and even warning surveys!) cannot replace proper planning. It is almost foolish to tap into expert collective knowledge only when it is already too late to make changes.
Water fundamentally has only one purpose: to relentlessly seek the fastest possible drainage. It has no moral qualms about achieving this goal by infiltration (and meanwhile contributing to corrosion). A roof with low flow velocity therefore inevitably poses serious risks at every penetration point. Stained ceiling plaster “indicates” that people have walked on the roof membrane too late but supposedly for maintenance purposes as “track walkers” (between photovoltaic mounts!), which replaces one problem with another. I say this not without reason: a flat roof is only cheap if its watertightness does not matter. At my age, I have witnessed multiple decades of construction mistakes—including those where technical fads far outweighed aesthetic blunders.
Solar or photovoltaic panels have an efficiency that largely depends on their tilt angle. Installing them individually at the ideal angle is only done where building regulations (or integration requirements) make it necessary. Otherwise, the roof pitch is designed to match the panel tilt, which may result in a sloped plane with rising perimeter edges instead of a horizontal eave and roof slopes only at the gable ends. THIS would have intrigued me to explore under Section 34, but a budget-constrained emergency architect rarely considers it. As Plan B, I would adjust the house footprint orientation accordingly—assuming cooperative terrain contour lines, which you have not yet clarified for us.
You can hopefully see now that there is hardly anything more unwise than asking the teacher a (first!) question just before the bell rings—especially if it is a matter of taste rather than understanding.
Am I right in suspecting that, as an apprentice wizard, you have already groped your way toward a design that seems nearly submission-ready, except for the still undecided roof shape?
hanghaus20236 Nov 2025 14:00What was your preference during the initial discussion with the general contractor? You should have indicated the style you like.
What did the general contractor show you as their usual type of construction?
bauhonk schrieb:
From the "passive-aggressive" comments about the flat roof, I deduce that it really is as problematic as people say. 😉 No, not at all. My criticism is only that the house is drawn first and the style is considered afterward. That is amateurish.
Look at this sentence:
bauhonk schrieb:
The architect asks what I have in mind, and I draw something, 😉
When you are asked, you don’t draw—you talk, you answer. You explain your spatial requirements, your needs, etc. Drawing is for the child; designing is the architect’s task.
