I am just starting to plan my house build, and the garage is already on my mind.
I would like to have a garage with direct access to the house.
For this, the garage needs to be attached to the house, and it is clear that sealing between the house and garage will be more expensive than if the garage stands separately.
A passage between the house and garage would also be possible in that case.
What are your experiences with this?
Thanks,
Tom
Thanks,
Tom
DaGoodness21 Jul 2023 12:44Yes, as a result, I have exactly 2 sqm (22 sq ft) less wall space available inside the house. However, I get direct access to the garage, which offers many additional square meters of space :p
WilderSueden21 Jul 2023 12:44DaGoodness schrieb:
Our floor plan wouldn’t have changed at all, except that the opening to the garage is now closed off. You’re forgetting about the walking path. Where you walk through, nothing else can be placed. No shelves, no washing machine, etc.
But that’s actually the smaller issue. By having a direct connection, you rule out all options where the garage isn’t directly positioned next to a certain spot on the house.
We have our utility and storage room right next to the front door. That’s where we keep extra drinks; a case of beer always stays in the kitchen. I store some tools there, the rest is in the garden shed. It’s less than 5m (16 feet) from the front door to the garden shed, and most tools are used outside anyway. With good planning, you don’t necessarily have to take a long detour just to get to a garage.
Buchsbaum21 Jul 2023 12:56The most important thing for a real man is the garage. Nowadays, there are already very nice man caves from Sonic and various other manufacturers that leave nothing to be desired. Therefore, I would also assign the garage the appropriate importance.
The biggest mistake is building the garage too shallow and too small. So here, always go big rather than small.
My garage, shaped like a barn, initially had a floor area of 200 sqm (2,150 sq ft), a height of 4 m (13 ft), and still had an upper floor with another 200 sqm (2,150 sq ft) of space. That was enough at first, but by now, I would make it a bit larger. Not all toys fit inside.
I will probably need to build a small vehicle hall on another property. Over the course of a lifetime, many wishes come up. Motorhome, boat, classic car, convertible, tractor, cars, maybe a lift, etc. You should be prepared for that.
Having direct access to the house is always good and practical. If you need to grab a beer from the fridge during summer, short distances are essential. Although, a proper garage should also have a fridge stocked with beer.
motorradsilke21 Jul 2023 12:56WilderSueden schrieb:
You’re overlooking the clearance path. Wherever you walk through, nothing can be placed there. No shelf, no washing machine,...
But that’s actually the smaller issue. With the direct connection, you’ve ruled out all options where the garage isn’t located right next to a certain spot on the house.
We have our utility and storage room right next to the front door. That’s where we keep extra drinks; a case of beer always stays in the kitchen. I keep some tools there, the rest is in the garden shed. It’s less than 5m (16 feet) from the front door to the garden shed, and most tools are used outside anyway. Well planned, you don’t always have to make a long detour just to get to a garage. That also depends on what the plot allows. It’s not possible on every property, and on some plots having the garage directly attached to the house is perfect. I wouldn’t generalize that.
We also have a side entrance door from the utility room—not directly into the garage, but just 1m (3 feet) away from the garage, facing toward the garage, the garden, and the garden shed. That was one of the best investments in the new house; I wouldn’t want to do without it. All supplies have a direct route to the utility room, laundry goes straight out into the garden to hang, and dirty gardening clothes go right into the utility room. It’s easy to quickly wash hands in the utility room after working outside. For that, I gladly give up less than 1 square meter (about 10 square feet) of floor space.
I would definitely do it the same way again and not have direct access to the garage, because a second entrance near the garage is more flexible.
Buchsbaum schrieb:
I will probably have to build a small vehicle storage hall on another plot of land. Over a lifetime, many needs arise.
Motorhome, boat, vintage car, convertible, tractor, cars, maybe a lift, and so on. It’s good to be prepared for that. Yes, we planned our garage accordingly – I can push my Robinson helicopter straight in from the garden at the back. If I still need to get a license for light aircraft, I’ll have to try to buy the neighboring plots to build a runway. A preliminary inquiry with the city is already underway.
