ᐅ Is it practical to install a photovoltaic system on the west or east side of a building?
Created on: 5 Jan 2020 18:42
kaho674
we are wondering whether we should install a photovoltaic system on the roof in the near future. The empty conduits for it are already in place. However, we have a hipped roof. On the south side, there is just over 20m² (215 sq ft) available for the system. Would it make sense to also use the west (or east) side to increase the area, even if the sun doesn’t hit it at the optimal angle?
kaho6745 Jan 2020 20:45
Oh dear, I signed up here. I have to admit that the overwhelming amount of information is completely confusing me.
I will look for our plans with the roof dimensions, etc., and then carefully start asking my beginner questions.
We also have a garage with a gable roof and an east-facing orientation. The house is located to the west.
boxandroof
5 Jan 2020 20:47
Read the FAQ from Pflanze. Paint the storage and set all surfaces. If you are diligent, you can also start experimenting with the layout. That would be a good starting point there.
kaho6745 Jan 2020 20:50
boxandroof schrieb:
Read the FAQs from Pflanze.
That’s exactly what I just did, and I was overwhelmed.
boxandroof schrieb:
Clear the memory and set all the areas. If you’re diligent, you can already start working on the layout. That would be a good place to start.
Yes, I can definitely figure out the areas, but I have no idea how big a module is, whether they are all the same size or each different, if there need to be gaps, and so on. I’m really starting from zero. ops:
boxandroof
5 Jan 2020 20:53
1.7 x 1 meter (5.6 x 3.3 feet) is standard. About 1 cm (0.4 inches) spacing between the modules. A bit more space at the edges, maybe 20 cm (8 inches)... there are some regulations for that as well... first check roughly what is possible.
There are also other module sizes available if needed.
hampshire
5 Jan 2020 21:51
East-west systems work really well. While you don’t get the maximum energy output per square meter, without a storage system you have more hours of self-consumption than with a south-facing system. It’s not that complicated. Your roof is as it is. When it comes to panels, electronics, storage, and so on, you will encounter “doctrinal disputes.”
ludwig88sta
13 Jan 2020 19:19
Do panels differ significantly in terms of efficiency? Is it worth researching the "best" or most efficient ones online at the time of installation and asking the installer to order and install those? Or is it better to simply go with the panels recommended by the contractor, since the differences are usually minimal?
