ᐅ Is having a fireplace still practical in new construction homes today – any experiences?
Created on: 20 Mar 2018 23:34
PSK
Hello!
My wife and I are currently in the planning phase for our single-family home and are wondering whether a fireplace still makes sense today, although we would like to have one.
To give some background: we both grew up with a fireplace and have always found it very appealing. There is just something special about a fire, and the “pleasant warmth” is great. For that reason, we always intended to install a traditional wood-burning fireplace with an open flame in our house. Specifically, we would like a real eye-catcher integrated into a wall, visible from two or three sides.
Almost every homebuilder we spoke to said that this no longer makes economic sense in modern houses and is more likely to cause overheating. However, it would be possible with all of them. Even a fireplace installation company advised against it. We are currently planning a system with an air-to-water heat pump and underfloor heating throughout the house (about 155m² (1,670 sq ft)), built to KFW55 standard (timber frame). A wall-integrated fireplace would have around 8 kW output, which is far too much. If at all, they recommend installing only a small freestanding fireplace with a maximum of 2-3 kW if we absolutely want one. But we don’t like those due to their size.
Thinking it over, I see the point of these arguments. In this setup, you have a consistent indoor temperature of about 21°C (70°F). You don’t really need a fireplace anymore. The companies estimate heating costs of around 500 euros. A cubic meter of firewood costs roughly 80 euros if you buy it prepared. So, potential cost savings are almost zero. And the chimney along with the fireplace and all the accessories would cost about 8,000 to 10,000 euros. Visually, it would also never quite look how we imagine it. Without a fireplace, we wouldn’t have an intrusive edge in the rooms and could position the doors more freely.
We also had a striking experience: about a year ago, we visited friends who had recently built a house and also have a fireplace. They proudly lit it even though it was already 22°C (72°F) inside, thanks to house automation and pellet heating. Although they barely put any wood in—so the fire was mostly smoldering—the fireplace kept running at full power. After two hours, the temperature reached around 26°C (79°F), and we were sitting in T-shirts (with -10°C (14°F) outside) in the living room. Another hour later, at 29°C (84°F), just before overheating, the friends opened the windows. The takeaway: expensive heat, a poor fire that I then effectively blew out the window!
What are your experiences with or opinions on fireplaces in modern homes?
Thanks in advance!
Steffen
8
86bibo
23 Mar 2018 15:45
Fine dust is also present INSIDE the house. Not in huge amounts, but what do you think is the material that you regularly have to clean on, around, and near the fireplace?
Wickie
23 Mar 2018 15:52
I’ve already had a fireplace in a new house before. Sure, it’s cozy. But it also means a lot of extra dirt and work. And pretty quickly, the place gets overheated.
The house I’m building now (still under construction) will have even better insulation and be even more airtight. Fireplace? No thanks. Not interested anymore!
Mycraft23 Mar 2018 16:52
I have everything here live and in color... we are 7 houses built by the same company between 2009 and 2011.
They have similar living areas and similar technical specifications.
3 houses have a fireplace. The fireplaces are usually used 1-3 times a year.
One neighbor last used their fireplace in December 2016.
We do not have one...
tomtom7923 Mar 2018 18:26
Better to have a nice fire pit or a pizza oven, etc., in the garden.
garfunkel
24 Mar 2018 00:24
However, it is easy to impress someone in front of a fireplace like that.
tomtom7924 Mar 2018 07:24
Hopefully the wife doesn't read this.
