ᐅ Is a workshop suitable as living space? Affordable!
Created on: 14 Jan 2008 18:16
U
Unregistriert
U
Unregistriert
14 Jan 2008 18:16
For our house, I specifically had the basement built with a ceiling height of 2.40 meters (7 feet 10 inches) and included a living space screed plus heating. Is this sufficient to use the hobby room as a living area, or do I need to consider anything else regarding the external insulation? Currently, there are several layers of bitumen applied on the outside and about 6 cm (2.4 inches) of expanded polystyrene.
Will the basement then officially count as living space and need to be recognized as such by the building authority? The planner included the hobby room with 33 square meters (355 square feet) as living space in the calculations.
U
Unregistriert
14 Jan 2008 18:17
Clear room height, finished dimension ≥ 2.40 m (7 ft 10 in)!
+ Insulation + heating according to the energy saving regulation
+ Lighting and ventilation: natural daylight, window size, visual connection to the outside including window sill height should be considered by the architect, otherwise it will remain a hobby room.
If building with a subsidy, the funding guidelines must also be taken into account.
U
Unregistriert
14 Jan 2008 18:17
Hm, the finished dimension is 2.40m (7 ft 10 in).
The heating is installed and sized for the room.
A two-leaf window with a masonry light well.
What about the insulation—will external insulation with polystyrene panels be sufficient?
U
Unregistriert
14 Jan 2008 18:18
You don’t need a light well; for example, a sloped area in front of the window works as well. It makes the room significantly brighter and more inviting than a light well because the angle of light incidence is more favorable.
U
Unregistriert
14 Jan 2008 18:19
Yes, I had also considered that, but it is not possible. I only have 3 meters (10 feet) from the window to the property boundary, and above that is the access path to the main entrance. The bottom edge of the window is at a height of 2 meters (6.5 feet).
U
Unregistriert
14 Jan 2008 18:19
Basically, you can use and live in your house however and wherever you want. However, your architect is not allowed to designate the area as living space.
If you receive housing subsidies, for example as a young growing family or similar, this space may not be counted, or in the worst case, the subsidy might not be paid.
