ᐅ Is it worth using edge protectors for the lower edges of KALLAX units?
Created on: 6 Sep 2024 08:37
sikeju
I have a question regarding the durability and protection of my IKEA KALLAX shelves, specifically about the edges of the lower sections that often come into contact with the floor or are frequently touched. I am considering whether it makes sense to install edge protectors on the lower edges of the KALLAX units.
Has anyone had experience with whether such edge protection is really worthwhile? I am especially interested in whether the protection effectively prevents scratches, chipping, or other damage, and if the installation or appearance is affected.
I would be very grateful for various opinions and tips!
Technically, edge protection significantly reduces stress on edges by absorbing impacts and protecting the surface structure.
Materials such as soft PVC or rubber are common. Regular inspection is important, as adhesive strips can loosen over time, leading to air bubbles and poor adhesion.
Installation is usually straightforward with self-adhesive strips. There may be some aesthetic compromises, but the protection outweighs this during heavy use.
PeoDaniel8 Sep 2024 08:05Hello sikeju,
I applied silicone edge protectors to the lower edges of my KALLAX shelves and can only share positive feedback. The previously vulnerable edges are now much more resistant to impacts and moisture. The material fits well and does not look intrusive.
The installation effort is minimal, and I believe the protection is definitely worth it, especially for shelves that are frequently used or moved in daily life.
PeoDaniel schrieb:
The material adapts well and does not look distracting.I can confirm that. What I often recommend is choosing the edge protection color to match the shelving. This way, the protection is hardly noticeable and still serves its purpose.
RENMA schrieb:
It is important to check regularly, as adhesive strips may come loose over timeA good tip is also to thoroughly clean and completely dry the surface before installation. This way, the protection adheres much better and lasts longer.
One more aspect I would like to add: If you are using edge protection, you should be careful when cleaning. Sometimes silicone strips can come loose due to aggressive cleaning agents or mechanical rubbing.
I recommend using mild cleaners and occasionally checking that the protective strips are firmly in place.
Thank you very much for the detailed answers and tips!
I found gregto’s advice on color selection and RENMA’s notes on adhesive performance particularly helpful.
I will probably try a self-adhesive silicone edge protector and, as recommended, pay close attention to thorough surface preparation.
However, I am also interested if anyone has long-term experience – for example, after several years – regarding how well the protection actually works on KALLAX edges and whether the effort is worthwhile in the long run?
