ᐅ Interior insulation with udiin, experiences
Created on: 14 Nov 2018 22:04
Mike99
Mike99
14 Nov 2018 22:04
I have a Poroton exterior wall without insulation and would like to insulate it from the inside using Udiin. However, I am concerned about the risk of mold growth behind the insulation. Are there any experiences or insights on this?
Regards, Mike
Dr Hix14 Nov 2018 23:17
I can’t offer any personal experience with this product, but basically, internal insulation can work with almost any insulation material. You just need to keep in mind that the dew point will generally shift to the inside surface of the wall, so a vapor retarder should be used, and it’s crucial to ensure that it is properly installed and sealed.
Is there a particular reason for your choice? I find that stuff relatively expensive.
Mike99
15 Nov 2018 06:40
External insulation is unfortunately not an option for us, as our house is already quite dark inside and it would make this even worse. Internal insulation was an alternative, and the material used is natural. However, I cannot find any experiences or feedback about this.
Lumpi_LE
15 Nov 2018 08:24
Why should that need reinforcing? You can also use reveals around window areas.
Interior insulation is always problematic and should only be considered for a listed facade.
Mike99
15 Nov 2018 10:34
Because the insulation, about 14 cm (5.5 inches) thick, pushes the windows further inward, resulting in less natural light entering.
Lumpi_LE
15 Nov 2018 10:44
That's why I write vouten; that way, you don’t have that problem.
