ᐅ Interior plaster – gypsum plaster – which type to choose – experiences?
Created on: 15 Jul 2018 21:16
M4X_111
What did you choose?
Is smoothed Q2 enough to just paint over?
Or do you need smoothed Q3?
We don't really like a textured finish.
fach1werk
18 Jul 2018 08:10
Q3 is just one more layer. Anyone who needs to sand significantly at this stage simply doesn’t have the skill and would have to sand after every layer. The key is to scrape sharply, basically with every layer, and that’s enough. Q4 is extreme; it’s not necessary here, and that’s where sanding is common.
Regardless of the level designation, applying filler requires practice and enough strength to handle a longer trowel so it goes quickly. Those who have that will be fast and effective.
Best regards, Gabriele
hemali2003
19 Jul 2018 07:16
As far as I know, Q3 means that the plaster is smoothed, but no additional layer is applied or sanded. In our case, it was (Q3 ordered) smoothed while still wet. The result was quite good.
Then they started spot-filling, which made it look uneven because the surfaces were different.
In the end, my husband filled and sanded everything by hand (without a machine), primed, and painted it, and the result is closer to Q4. It looks really good! We definitely wouldn’t have been happy with the other finish.
Nordlys
19 Jul 2018 07:32
Please search online for the Knauf datasheet on joint filling. I am not allowed to provide a link. It contains all the necessary information.
