ᐅ Is the installation of the insulation satisfactory?
Created on: 11 Feb 2015 19:35
HardyHard
Here is an update from the construction site: today, the on-site cast concrete corner pillars were insulated.
Is this type of installation still within acceptable tolerances?
Green insulation boards and exposed insulation on a wall during construction progress.
Green wall insulation boards being attached to the building wall during shell construction.
Green insulation boards on an exterior wall during shell construction, scaffolding in the background.
Close-up of insulation material between green insulation board and concrete blocks.
Exterior wall with green insulation board and wooden support during construction work.
Exterior shell construction with green insulation boards and scaffold on site.
Thanks and regards
V
Voki1
18 Feb 2015 20:01
Admittedly, he has only identified the obvious flaws. Whether the rest of the work—especially filling the gaps with expanding foam—is done correctly, I would at least dare to doubt here. He is responsible for supervising the construction process on behalf of his employer and will likely try to minimize any additional repair costs.
EveundGerd18 Feb 2015 23:05
I would now involve an expert!
Bauexperte
19 Feb 2015 00:16
EveundGerd schrieb:
I would now involve an expert surveyor!
Overdue 😉
Regards, Bauexperte
Mycraft19 Feb 2015 08:58
HardyHard schrieb:
Gaps of 1 to 2 cm (0.4 to 0.8 inches) are within tolerance and do not require correction.
He should provide this to you in writing or show the relevant section in the insulation material’s installation guidelines... you will find that he cannot substantiate his statement...
HardyHard13 Mar 2015 06:31
Good morning everyone,
Yesterday, there was a site inspection by an independent building expert. The result was that the workmanship and materials (expanding foam) do not meet the standards.
A few other minor issues were also added to the list.
Thanks for the responses and have a great weekend.
Regards
V
Voki1
13 Mar 2015 06:37
Thanks for the update. The money spent on the expert already proved worthwhile. ;-) While it was obviously not acceptable in this case, he will surely find many other issues that are invisible to us laypeople. Well done. :-)
