ᐅ Insulation below vapor barrier moldy?
Created on: 8 May 2019 10:40
Paulemann1
Paulemann1
8 May 2019 10:40
I accidentally drilled into the vapor barrier in the wall. At first, I thought the insulation looked a bit gray. However, when smelling it, there is no odor. It is also not damp. Shouldn't the insulation smell moldy or be damp if it were moldy?
Unfortunately, I can’t take a photo because I don’t want to damage the vapor barrier any further.
Paulemann1
Paulemann1
8 May 2019 11:13
One more question. The hole is 3-4cm (1-1.5 inches) in size. Can it still be patched, or should the membrane be completely replaced?
pffreestyler
8 May 2019 11:47
Simply use a tape specifically designed for this purpose to patch it. This type of tape is also used to seal the joints of the vapor barrier.
Paulemann1
8 May 2019 12:49
Thank you for the help!
pffreestyler
8 May 2019 13:38
This only refers to the hole. Regarding the alleged mold, surely others can provide you with an answer.
garfunkel
25 May 2019 21:49
This could be mold or simply dust. If it is dust, it means it was either introduced during installation or there is air leakage in the insulation. Air leakage would be a good sign, as it likely means it is not mold; however, insulation that allows air leakage does not insulate very well. Without a photo, it is difficult to say more.
