Hello Forum!
I plan to insulate a garden shed with a basement (5x7m (16x23 ft))!
Currently, there is simple exterior wood tongue-and-groove boarding, a 13cm (5 inch) wooden frame, and interior tongue-and-groove boarding again.
My goal: to make it cooler in summer and warmer in winterâ is this possible?
I intend to fill the cavity with about 10cm (4 inches) of insulation fleece and use a vapor retarder adhered on the inside.
Questions:
Thanks
wolf_2d
Questions:
- Which vapor retarder (sd value)?
- Which insulation material (mineral wool, rigid boards, etc.)?
- Or is this even worthwhile, considering I also have an air conditioning system installed that can cool in summer and heat in winter?
Thanks
wolf_2d
pagoni202019 Feb 2021 20:17The wall is one thing. You should also consider the roof, windows, door, and floor.
You can try this approach first, as the result is reasonable and the cost is within limits, plus itâs something you can do yourself. Just align the materials with the price and the specified better insulation value, but keep in mind the uninsulated roof and so on.
I wouldnât do too much there.
Yes, I can manage that... I would install the battens, put in the insulation, apply the vapor retarder, and then reinstall the battens.
I'm still not sure about the vapor retarder... There are many different types (SD value, etc.) to consider. What should you pay attention to? If necessary, even the 'cheapest' one will do.
pagoni202020 Feb 2021 12:12I wouldnât spend too much money just to achieve a specific value. A standard option should be sufficient since you would otherwise need to insulate the entire structure thoroughly and without any defects, which would almost certainly be prohibitively expensive. As mentioned before, having an expensive version in one place and almost nothing in another would be a waste of money.
Often there are also offers or second-choice options that can help you reach your goal just as well. I know someone who did something similar and has already spent nearly 8,000.- hiding costs with occasional "upgrades." However, the floor and roof are still almost uninsulated, single glazing, etc., so the heat just leaks in or out somewhere else... 🤨. This is exactly the kind of approach I would advise YOU NOT to take.
