We are planning a basement for our new house, which will be used as a utility basement. The technical room (including the heat pump and mechanical ventilation system, etc.) will be located in the basement. The other rooms are intended for storage, a workshop, and storage areas. Actual living use is not planned; however, I can imagine that our children might later use the space for hobbies (music, party room, foosball, etc.) if the climate there is reasonably comfortable. Also, it should not be freezing cold when working in the workshop during winter.
What about ventilation? I have planned a few basement rooms without light wells and was considering possibly connecting them to the mechanical ventilation system if the humidity gets too high.
Now I wonder, how are utility basements commonly insulated nowadays and what effects does each approach have?
- No exterior insulation at all and only insulating the basement ceiling/stairwell? Is it then acceptable for the heat pump and mechanical ventilation system to be installed in the basement? Can the basement be connected to the mechanical ventilation system, or would that completely negate the heat recovery?
- Exterior insulation but no separate heating in the basement?
- Exterior insulation and underfloor heating in the basement?
What temperatures and humidity levels can be expected with the different options? I would be very interested in your practical experience.
"Doing the same thing again, but without trauma" is a understandable reason for choosing a particular house design. However, such options are also available from builders who do not refuse to include the basement within their contract scope. The top edge of the basement ceiling is a doubly critical junction: many things can fail to align properly there, and the blame usually falls on the other party (if a second contractor is involved). For this reason, it is common to select a builder who either handles both parts themselves or makes the basement builder a subcontractor. By linking responsibilities this way, the homeowner avoids being left out in the cold.
