I own a garden shed without a basement. It is built on a concrete slab. I recently checked the floor structure and found the following layers: roofing felt, a 6cm (2.4 inch) thick wooden board, and laminate flooring. Now I want to remove all of that and properly insulate the floor. What materials can I use for this?
Thank you in advance
Luca
Luca
Hi
Exactly, and this is where a sharp pencil is an advantage. The result will be that the money saved on insulation costs can fund a big party with friends. For those occasional moments when you want to spend time in the garden shed, a sturdy oak floor and wooden walls are sufficient.
Good luck
Good luck
This is how it looks because insulation is not a heating system. I maintain that the effort is simply too high and the benefit too low. If the house has deficiencies, then invest in insulating the windows and doors. Also check the transitions between the walls and the roof.
This can already be done for a relatively low cost.
Okay, I understand. My reasons are that we want to feel comfortable in the garden. But 12°C (54°F) room temperature is just too cold in winter. Alright, I will buy a fan heater and then it will work. I am less concerned about the energy costs.
Thank you very much for your information.
Georges-121 Sep 2015 13:13My situation is similar:
I want to convert my basement into a workshop. Since I will be retiring soon, I will probably spend time there daily.
The floor, walls, and ceiling are concrete, built in 1996. The special feature is that this basement is built into a hillside, and my parking space is located above the basement ceiling.
My plan is to insulate the floor slightly before laying vinyl (or similar). I have no issues with the doors, as there is currently a step of about 5cm (2 inches) height.
I will paint the walls and ceiling.
