Since I like to be prepared well in advance, an important question for me is the flooring.
The current apartment has laminate flooring, which I don’t really like.
I’m not sure if it was poorly insulated, but the walking noises are quite disturbing. It also sounds very hollow when you walk on it.
Are there special insulation options for this, or should I rather choose parquet flooring, even if it is more expensive?
Hans
Hans
Karl-Steffen-128 May 2014 08:41Hearing impact noise with laminate flooring is new to me. Parquet is naturally a bit more upscale, and if it is installed correctly, it should be quiet for quite some time. However, it won’t be completely silent either.
Ricardo-125 Feb 2016 08:41We also have laminate flooring in the house and are satisfied with it. Upstairs, I installed impact sound insulation under the laminate. This makes a noticeable difference, and hardly any noise can be heard here.
On the ground floor, I laid a vapor barrier under the laminate. The basement is not heated, and otherwise moisture can build up there. I have already seen moldy laminate, which started at the baseboards.
