Bienenallee30 Aug 2015 16:34Hello everyone!
I cannot insulate my bathroom from the basement and now want to do it under the floor tiles instead. Which material would you recommend? It will of course reduce the ceiling height, so the thinner, the better.
Thanks and best regards
jupartner1 Sep 2015 20:27PUR boards are suitable; they are not as thin as vacuum insulation panels but noticeably thinner than conventional materials. The supplier of the PUR boards can calculate the U-value (thermal transmittance) for you. Ideally, you should aim for the legal requirement (U = 0.30), with at least 4 cm (1.6 inches) of insulation thickness; otherwise, you won’t see a significant effect.
All the best
Susanne Junghans
All the best
Susanne Junghans
Bienenallee11 Sep 2015 07:28Hello,
first of all, thank you for the advice! More information: My house is older than 1945, built with a steel beam and concrete structure, which contains a high proportion of sand and some small stones. The screed needs to be removed; it mainly consists of sand... Currently, the water pipes are embedded in it and will also have to be removed. Removing it will not affect the height; there will definitely be a step to the adjacent room due to the insulation because the floor will be retiled. The entire house is meant to meet KfW standards, the consultant says there is some flexibility here and there, and the architect believes that the space below still allows room for a thin layer of insulation. So, the plan is to add insulation from above and below, according to him.
