ᐅ Installing Light Fixtures
Created on: 18 Nov 2015 09:29
AnneShirley
Good morning,
we have just moved into a newly built house for the first time and are a bit unsure about how to install the lights. In our rooms, there is a long, thick black cable hanging from the ceiling, from which three thinner colored wires come out. Should we simply cut off the thick cable? How exactly should we handle the three small thin wires?
I’m attaching a picture for better understanding 😉
alexm86
18 Nov 2015 10:10
Don't forget to turn off the power at the main distribution board before cutting!
AnneShirley
18 Nov 2015 10:14
Yes, that is the first thing we will do! 🙂
Jochen10418 Nov 2015 10:25
Attention! Do not simply cut it off, because you need the wires! Otherwise, I can only agree with @lastdrop: Let someone who knows what they’re doing handle it.
SirSydom
18 Nov 2015 10:38
If heat or UV radiation is expected from the lamp, the now unprotected single wires must be covered with appropriate sleeves; otherwise, they will become brittle and crumble.
This may not happen within 5 years, but if the insulation crumbles away after 30 years, that's also a problem.
AnneShirley
18 Nov 2015 10:42
No, there shouldn’t be any heat generation there... but we probably won’t live here for long anyway, since we plan to build our own home 😉
Sebastian79
18 Nov 2015 11:00
That is certainly an argument...
