ᐅ Installing Electrical Wiring in the Ceiling – From Light Fixture to Switch
Created on: 30 Apr 2020 08:51
Q
quattro123Q
quattro12330 Apr 2020 08:51I’m just asking out of curiosity; the work will be carried out by a professional (who is currently on vacation, so I’m asking here).
There are certainly many different approaches. But is it correct that a very common method in new construction is to install as many conduit pipes as possible in the ceiling and then simply pull all the cables through these conduits to the boxes?
Presumably, all the power outlets are wired directly from the distribution board. But what about the lights? Are the conduits for the lights run directly to the locations where the switches will be installed? Or are these conduits also routed first to the distribution board?
This concerns a “traditional” electrical installation. No bus systems or similar.
I’m not a professional...
A lot has already been installed in our ceiling. However, cables were laid at the same time. I hardly think anyone wants to pull cables unnecessarily through empty conduits. Or are you talking about recessed lights? Usually, only junction boxes are planned for those.
In our case, however, it’s a KNX installation.
If you’re not using KNX and don’t plan to “retrofit” it later, why would you run cables from every lamp back to the distribution board?
Q
quattro12330 Apr 2020 09:08No idea, it doesn’t entirely make sense to me either, but I wasn’t really sure myself.
Lumpi_LE schrieb:
With a traditional installation, the connection goes directly to the switch – otherwise, no one can manage the large amount of copper in the distribution board. Not only that, but the loop resistance also increases due to unnecessary cable length,
