Hello
I want to cover my walls with drywall panels to create a smooth surface.
Now my question is: do the panels or a battens framework stick directly to the existing wall, and then the panels are screwed onto that?
What do I need to consider?
If I use a batten framework, do I also need to apply a vapor barrier foil on the battens?
Maik
Maik
Oh, right,
I learned during the drywall training that wood is completely unsuitable because it can warp.
Standards and practical experience sometimes differ here and there.
I have successfully installed battens vertically for 18 years.
For the 30cm (12 inches) spacing, at least one batten was added upfront to make it somewhat manageable for a DIY approach, so you don’t have to screw in even more battens with a 25mm (1 inch) spacing.
No, seriously. I have no problem being corrected if my opinions or I are wrong. And with a professional statement, you are certainly on the safe side. But a forum is meant for exchanging experience and opinions, and that’s what I contributed to.
And now I’ll get back to the topic.
Regards, Dirk
Regards, Dirk
I have another question regarding the vapor barrier or vapor retarder.
Since I am not installing insulation between the drywall and the exterior wall, do I need a vapor barrier or vapor retarder there?
The exterior wall is built from bricks. If I have seen it correctly, it is a type of cavity wall (bricks – cavity – bricks).
Maik
Maik
Hello @Winkli,
the cost of the insulation material and the drywall panels is only the tip of the iceberg.
Especially work on the thermal envelope should be properly planned and executed; otherwise, it is highly likely that not only the money spent on it will be wasted, but potentially also the building structure.
Best wishes for the new year
KPS
KPS
