I would like to install LAN cables in every room of the house after construction. The walls upstairs are made of drywall. Is it possible to run a LAN cable through the attic and then push the cables into the walls from there?
There is currently no flooring or covering in the attic. If the insulation is removed, it should be possible to access the drywall, right?
There are 3 rooms, and I want to install 2 LAN cables in each. I would prefer not to remove the wallpaper, but rather drill a hole next to an existing electrical outlet and push the cable in from the attic.
Thanks in advance for the answers.
K.Brodbeck2 Mar 2014 20:05Then probably planned incorrectly ;-(
Maybe talk to the craftsman who built the wall. It might be possible to fish the cable through.
Good luck!
K.Brodbeck
Good luck!
K.Brodbeck
