ᐅ Installations and drilling in hollow clay bricks
Created on: 28 Sep 2016 11:44
Kaspatoo
I have searched extensively but have not found a clear answer.
In the building and service description offered to us, hollow clay bricks are specified for both exterior and interior masonry.
Exterior walls use 24cm (9.5 inches) hollow clay bricks with a 16cm (6.3 inches) insulation layer and mineral plaster.
Interior walls use either 11.5cm (4.5 inches) or 17.5cm (7 inches) hollow clay bricks, depending on whether they are load-bearing or not.
By hollow clay bricks, I understand those with vertical hollow chambers inside that are not filled with insulation material.
My friend said my planner might be crazy, with the following arguments:
- Interior walls do not need to provide insulation, so hollow clay bricks are pointless.
- Hollow clay bricks make it difficult to cut installation channels and drill anchors for, e.g., wall cabinets.
- Specialized anchors would be required for drilling.
- Calcium silicate bricks are much better suited for interior walls because they are easier to chase and provide better sound insulation.
- The latter points also apply to the exterior walls; installations are difficult and only possible to a limited extent (some kitchen cabinets are to be hung on the exterior wall, and the TV wall is also on the exterior wall for electrical outlets).
- This means that the exterior walls could also be built in calcium silicate brick.
- The slightly lower insulation performance compared to hollow clay bricks is not so important because this can be compensated more easily through insulation.
My question now is: Is this true? Are installations significantly more difficult to carry out compared to, for example, calcium silicate bricks?
Either way, I tend to ask the planner whether we could use 17.5cm (7 inches) bricks instead of 24cm (9.5 inches) ones and compensate with slightly thicker insulation (if I understand correctly, insulation provides more thermal resistance than brick thickness).
Also, we plan to build with facing bricks and mineral wool instead. Here, I would also prefer a 17.5cm (7 inches) brick; otherwise, the wall would become even thicker due to the facing brick.
Ultimately, the goal is still to achieve KfW55 standard (controlled ventilation is planned, whether air-to-water heat pump or gas heating is still undecided).
Musketier28 Sep 2016 15:36
As far as I know, different building materials should not be mixed. So, changing only the interior walls to calcium silicate bricks does not make sense.
Additionally, every builder has a preferred building material. If you deviate from that, it becomes unnecessarily expensive because the favorable purchasing conditions no longer apply. In that case, it’s better to look for another builder who typically uses calcium silicate bricks.
