ᐅ Installation of Controlled Residential Ventilation – In the Ceiling or Externally?
Created on: 14 Jul 2014 23:39
Kazazi
Hello dear forum community,
We are about to make a decision regarding a ventilation system. Among other options, we have two offers for a mechanical ventilation system with heat recovery to choose from, which differ in how the ductwork is installed. Naturally, both providers claim that their system is the best.
To help us form our own opinion, we would appreciate hearing about your personal experiences or any objective information explaining why one solution might be preferable over the other:
Provider A wants to route the ventilation ducts inside the precast concrete ceiling between the ground floor and attic, stating this is simply the best solution in new builds; other methods would only be used when retrofitting a mechanical ventilation system in existing buildings. So far, the only specific advantage mentioned is the appearance, as this avoids visible duct boxing outside the ceiling. In this setup, the rooms on the ground floor receive air from above, while those in the attic get air from the floor level. A detailed price quote is still pending.
Provider B intends to run metal ducts from the utility room on the ground floor up to the converted attic (loft), ventilating the attic rooms from there. Visible duct boxing would occur in two narrow spots in the hallway and, if I understand correctly, also at one spot in the converted attic. He claims that this system works significantly better compared to plastic ducts with smaller diameters, which could also be installed in the ceiling. In addition, it avoids an unattractive tangle of distribution ducts in the utility room, and the installation is approximately $1000 cheaper.
Regarding appearance, we don’t consider either a tangle of ducts in the utility room or a few discreet duct boxing sections as problematic, so this factor is not decisive for us. Therefore, we would like to know what other advantages or disadvantages these options might have.
Does option B really perform better? Is there any objective proof of this? And is my husband right in thinking that option B would also be easier to service or handle in case of faults, because the ducts are more accessible? Or are there functional or other significant advantages to option A, apart from appearance, that we should be aware of?
I look forward to your experiences, opinions, and advice on this, thank you very much,
Kazazi
One0018 Jul 2014 22:49
Curb forms are not necessary for us either, as the pipes run beneath the screed.
Kazazi
19 Jul 2014 09:28
Thank you again for all the responses.
@nordanney: Why is routing inside the ceiling easier? And am I wrong in thinking that cables not located in the ceiling are harder to access for maintenance?
nordanney
19 Jul 2014 09:34
@ Kazazi
Because the pipes are simply laid on the formwork or the lower reinforcement. It’s very quick and easy.
What kind of maintenance do you mean? If proper filters are used, the pipes stay clean forever.
Kazazi
19 Jul 2014 09:38
Ah, thanks. I meant the (hopefully unlikely!) case that something does happen and you need to access the pipes. A tradesperson I know just told me a story where children managed to open a ventilation opening and fed marbles into it, for example...
O
oleda222
19 Jul 2014 19:48
That’s why I wouldn’t want them on the floor. Besides marbles, there’s also, for example, the 1.5-liter (50 fl oz) bottle of cola that someone (hopefully by accident) poured in there, or the cat that couldn’t find any other place...
When routing pipes through the ceiling, they must also be taken into account in the structural calculations.
Bauabenteurer
21 Jul 2014 10:50
According to the information we received, installing the ducts in the floor is a more cost-effective option. It is better to run the supply and exhaust air in the ceiling (preferably during the masonry or floor pouring stages; later core drilling in the shell construction is possible but expensive). With supply air in the floor, you will face more work, especially when installing the floor covering. And the bottle of cola should be an argument too!
