ᐅ Installation of an Air-to-Water Heat Pump – Is This Setup Correct?
Created on: 6 Jun 2020 13:58
Mertha257
Hello dear forum members,
We have been considering the installation location for our planned air-to-water heat pump for several days now. It is intended to be placed on the east side of the house, specifically in the gap between the bay window wall and the back wall of the garage (see image).
The discharge direction would be toward the east, away from the house, but after about 3 meters (10 feet) there is the neighbor’s garage/garden shed.
After researching various manufacturers, the heat pump fits in this space, as the minimum clearances from walls at the back and sides range between 15–40 cm (6–16 inches), which we can achieve.
However, I have two concerns:
1.) Possible thermal short-circuit: Given the enclosure by the bay window, our own garage rear wall, and the neighboring building, will the air-to-water heat pump be able to discharge the used, cooler air effectively enough and far enough so that sufficient fresh, warm air can flow to the intake? I do not want to compromise the efficiency of the heat pump due to the installation location. Unfortunately, there is no other feasible place to install it...
2.) Noise impact: It is often advised that air-to-water heat pumps should not be placed in wall niches or corners to avoid sound amplification/reflection. Although I plan to decouple the heat pump as much as possible and build a proper foundation, our bedroom is located on the first floor directly above this spot.
What are your thoughts on these two points? Do you have any experience regarding this? Point #1 is especially important to me, as I have found some good approaches to avoid or reduce noise.
Thank you very much for your advice!
Have a great weekend everyone!
Grundrissplan einer Garage mit Nachbarwand und Erkerwand, technische Markierungen
Nida35a10 Jun 2020 10:16
There are outdoor units with a noise level of 35 dB, designed especially for townhouses where each one is placed in front of the bedroom. Ours is located in front of a wall without windows and can only be heard from a distance of about 3–5 meters (10–16 feet) away from the unit.
Best regards, Nida35a
Karl H.
10 Jun 2020 10:42
TA. Noise:
- In central areas, village areas, and mixed-use areas
daytime 60 dB(A), nighttime 45 dB(A)
- In general residential areas and small settlement areas
daytime 55 dB(A), nighttime 40 dB(A)
- In purely residential areas
daytime 50 dB(A), nighttime 35 dB(A)
T_im_Norden
10 Jun 2020 11:10
And the measurement would be taken 50 cm (20 inches) in front of the open window of a room requiring protection.
