ᐅ Location of the heat pump – in the south?
Created on: 1 May 2016 20:27
tabtab
tabtab1 May 2016 20:27
after much consideration, we have now decided to go with an air-to-water heat pump.
We are currently planning the installation location. Initially, we planned to place it on the north side, where it wouldn’t bother anyone. It would be located under the bathroom, and the neighbors are quite far away.
However, I’m wondering if that is really the best option. In one thread here, someone mentioned that it’s better to install it on the south side. They didn’t explain why, but it makes sense to me because of the higher temperatures. What are your thoughts? Does it make a significant difference? Especially in winter, it wouldn’t hurt if some sunlight hits the unit, right? Or could there be problems in summer when the device is exposed to direct sunlight and high outdoor temperatures?
I’d appreciate any experience or insights.
Nordmann
1 May 2016 23:06
Place it as far away from your neighbor as possible! Everything else is a lower priority. The air flow is so strong that the slight extra solar heat doesn’t make a difference.
It is more important that you treat your neighbor the way you would like to be treated. Therefore, pay attention to a quiet system.
tabtab1 May 2016 23:30
That goes without saying. We specifically bought a silent version with 54 dB. But that wasn’t the question... the other point interests me more.
bierkuh83
2 May 2016 11:53
If by south you mean southern Italy, then that definitely makes sense.
Just kidding. Definitely set it up facing south, then paint the whole thing black and place a few mirrors to catch the last bit of solar energy. That will probably save about 10 cents per year.
Nordmann
2 May 2016 22:29
To reiterate: The air temperature in the microclimate around the house is ultimately very similar. Therefore, the effect is negligible.
Curly
3 May 2016 11:07
We have an air conditioning unit with a noise level of 51 dB (the outdoor unit), which we find quite loud. We only switch it on briefly around midday during the peak of summer to avoid disturbing anyone too much (the neighbors are usually at work then). For that reason, if I were you, I would place a heat pump as far away from your neighbors as possible—that would be my top priority.
Sabine
