ᐅ Installing Sonos Ceiling Speakers in a Concrete Ceiling?
Created on: 28 Jun 2020 22:00
imsi123
Hello, I want to install a Sonos 5.1 system in our new build using a Sonos Amp (already available), an existing subwoofer, two Sonos One speakers (available) for the front, and two Sonos One as ceiling speakers (rear) above the couch (freestanding in the room). However, I’m not very happy with the look of having two network outlets, two power sockets, and the two ceiling mounts in the concrete ceiling.
So now I am considering installing the passive Sonos Architectural ceiling speakers. The concrete ceiling is 20 cm (8 inches) thick plus plaster. I don’t think it will be possible to cut a hole 13 cm (5 inches) deep and 21 cm (8 inches) wide into the ceiling to fully recess the speaker. Are there any mounting frames available that would allow the speakers to stick out a bit? Or any other ideas on how this could be done? Or different speakers?
Kind regards,
Ben
Aphrodithe
30 Jun 2020 15:52
If they are to be installed on the ceiling, simply use a ceiling outlet with a three-phase power track attached, and then connect as many One modules as desired. Lighting can also be connected if needed!
imsi123
30 Jun 2020 21:24
So, Sonos has already responded. I have to say, they are really quick; the answers are always very fast and provided by knowledgeable staff.
From what we have discovered so far: two wired front speakers plus two wireless speakers, a subwoofer, and a “virtual center” create a surround system capable of playing Dolby Digital content in 5.1. True 5.1, including a center channel, is only possible with the new ARC if you add two rear speakers via wireless or wired connection (in combination with an AMP). However, you also need the Sonos subwoofer, because the subwoofer output on the AMP cannot be used when the AMP is configured for rear speakers!
Best regards and thanks for the information!
