ᐅ Installing a retractable insect screen sliding door as a retrofit?
Created on: 27 Jul 2021 21:33
squier23
we are trying to decide whether to get an insect screen sliding door for our PSK patio door directly from the builder (for 975 euros) or have it installed afterwards. Similar kits can probably be found online for less, but would there be any advantage if the builder installs it? They would probably just mount it on the outside of the frame or in front of the roller shutter box, right?
DerGuteTon17 Aug 2021 17:55Nida35a schrieb:
Have the middle muntin made at hip or elbow height, because of trays and such. That would actually be the result. The handle recess is also located in the middle muntin. In any case, it’s practical. For me, it was more about visual aspects, since we currently have an unobstructed view through the (sometimes also clean) floor-to-ceiling window panels to the outside greenery. And then the crossbar just hangs there.
Bertram10017 Aug 2021 18:01I have a sliding door without bars, 250cm (98 inches) long, that keeps flies out. It’s almost completely invisible. Guests don’t see it at all and often walk right into it at first. 😀
This stuff is seriously overpriced.
Basically, they are aluminum frames with plastic mesh inside.
You can easily make these yourself for windows, as there are regularly kits available at stores like Lidl and others.
The quality isn’t any different, but it costs only a tiny fraction of the price.
I would always make something like this myself; it’s not rocket science. And if you measure wrong or make a mistake cutting it, you just do it again—you’ll still have saved the cost of a cheap used car or a nice vacation.
apokolok schrieb:
This stuff is really way too expensive.
In the end, these are aluminum frames with plastic mesh inside.
You can very easily make these yourself for windows; there are regularly kits available at Lidl and similar stores.
The quality is no different, but it costs just a fraction.
I would always do this myself, it’s not rocket science. And if you measure or cut wrong, you just make it again—you still save the cost of a cheap used car or a nice vacation. Objection!
It’s not cheap plastic, and what you get at discount stores is junk.
