ᐅ Installing a Drainage System in the Basement After Construction
Created on: 20 Aug 2025 03:27
Michel56
Michel56
20 Aug 2025 03:27
I am currently working on waterproofing my exterior wall and installing new drainage. I had the idea to install a water drain in the basement that connects to the drainage pipe. Does anyone have any suggestions on how to do this? I would prefer not to break up the concrete slab. Are there any good wall drains available that are flush with the floor?
wiltshire
20 Aug 2025 09:22
What kind of water from the basement is this that should not go into the sewer system?
In my opinion, a lifting station is better than a "hole" with a backflow valve.
hanghaus2023
20 Aug 2025 11:18
wiltshire schrieb:
What kind of water from the basement are we talking about that shouldn’t go into the sewer system?
In my opinion, a lift station is better than a simple pit with a backflow preventer.
In my opinion, even better than without a backflow preventer. 😉
Michel56
20 Aug 2025 12:51
wiltshire schrieb:
What kind of water from the basement is it that shouldn’t go into the sewer system?
In my opinion, a sump pump system is better than just a “hole” with a backwater valve.
The sewer connection is located above the concrete slab. A sump pump system is not an option due to contamination. The room is going to be converted into a honey extraction room for my beekeeping operation.
hanghaus2023
21 Aug 2025 09:11
Just to understand correctly: You want the dirty water to drain into the ground through the drainage system? 😳
wiltshire
21 Aug 2025 11:17
hanghaus2023 schrieb:
Just to understand. You want the dirty water to drain into the subsoil via the drainage system? 😳
As long as no alkaline or acidic cleaning agents or disinfectants are used, that should not be a problem. Many beekeepers find it difficult to avoid sodium hydroxide. Of course, this substance does not belong in a drainage system and should only be neutralized and discharged into wastewater in small quantities. Hobbyist beekeepers are usually "safe" in this respect and have a high reuse rate.
However, the insistence on managing without a sewer connection and the supposed "impossibility" of installing a lift station or pump seems a bit odd to me without further explanation.
