Hello!
Has anyone here ever tried retrofitting an inner drawer pull-out mechanism? You often see them in kitchen showrooms. When you open the outer drawer, the inner one is pulled out as well. I found it quite practical, but it is not available as a standard feature at Ikea.
Daniel
Daniel
IKEA-Experte14 Apr 2016 15:34Great, thanks.
The 25mm (1 inch) hole is an issue for many, for whatever reason.
How is the part attached to the inner drawer?
So far, I have only placed it loosely. I removed 1.8mm (0.07 inches) using a router, which results in a slight oversize fit. The red things are still the release films from an adhesive tape, so I assume they are usually just stuck on. However, I think I will secure it with a screw from behind.
Just for completeness. Instead of Utrusta, the Blum aluminum front Z31L1036A (white) (€15.20) with the side plastic holders ZIF.71M0 (white) (€4.70) should fit. If that works, then the ZIF.80M7 (white) handle with driver can be installed (€6.62).
However, simply shortening the aluminum fronts is definitely more complex than the solution proposed so far.
IKEA-Experte12 Oct 2016 22:13The parts are for height M, while Maximera frames are rather height N. There is nothing available for that.
kaderekusen12 Oct 2016 23:10Wouldn't three strong magnet pairs embedded into the wood, which was previously drilled out, be able to achieve the same result... Just a tip.
